Question about Gateway 832GM PC Desktop
Possible virus my sons 832gm was running slowly with corrupted files he did an f11 reboot and now his monitor is 90% blocked by a big whitebox/screen. the computer doesnt seem to respond to any commands, and gateway did not provide a restore disk.
    Genius:
  • 1,601 Answers
Try starting in safe mode. If it works then you need a graphics driver.
Posted on Jan 01, 2008
Hi! My laptop hp ProBook 6360b windows 10 OS, has encountered a blue screen problem. Stopcode: NTFS FILE SYSTEM. Unfortunately, I can't log in because I set log in screen password. Please help, how to go...
redux 1: my bad, W10 does not belong on this PC, ever.
(and expect HP support, you are now owned by MS
Microsoft 100% owned.
i cant read the last words on the line. (end lines)
the bar code can be scanned with cell cam.
then MS codes it.
installing what software, what is it or better the full URL link.
1milliions of software,some good some virus. endless viruses.
boot the PC, power on, and hammer the F11 key
bam HP recover mode, pick repair startup files.
if recover is dead say so...
if repair startup fails do the full restore.
there are 50+ MS BSODs now, the above i cant see, thanks to fixyha, shrinking it.
startup file missing
startup files corrupted
HAL corruption
one wrong thing to do is installed Video card drivers and get the HAL error.
or infected software of any kind.
next time tell the helper what software you loaded and from whom.
the BSOD list is bigger here.
https://www.lifewire.com/blue-screen-error-codes-4065576
and overwhelming list. all in HEX.
the hex code is what matters. most.
if F11 fails. tell that first.
Sep 04, 2017 | HP Computers & Internet
Toshiba laptop keeps rebooting
You probably have a mbr virus.
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Sep 02, 2012 | Toshiba Qosmio F25-AV205 Notebook
C00021A Fatal System
https://www.youtube.com/watch?v=1C9oIsK5CCk
Sep 29, 2017 | HP Compaq nc6400 Notebook
Acer Aspire M5100 ..... Will not recognize EXE files (will not open most programs) ... Lags, freezes goes to blue screen and often completely and suddenly shuts of Everything (fan monitor etc.) except the...
This fault can be caused by so many different things:
You should start by tracing back through the recent history of hardware, software, drivers or settings changes to the computer between now and the last time that the computer was working properly to eliminate as many items as possible from the long list of possibilities below so you can isolate the precise cause.
Virus or spyware or other malware infection;Overheating due to insufficient number of internal cooling fans;Dry or insufficient paste between the Central Processing Unit (CPU) and the heat sink/CPU cooling fan;Failed or disconnected CPU cooling fan;Dust blocking input or output of cooling air inside the computer case;Dust blocking the input of cooling air to the CPU heat sink by the CPU cooling fan;Device conflict;Device driver conflict;Corruption of Windows system files;Corrupted Windows Registry during registry editing;Multiple installed anti virus programs in conflict with one another;Multiple installed Firewall problems in conflict with one another;Multiple installed anti malware programs in conflict with one another;Incorrect Firewall settings;Corrupted interrupted or incomplete Windows upgrade setup process;Corrupted interrupted or incomplete Windows repair installation keeping previous files and settingsCorrupted interrupted or incomplete Windows recovery operation;Corrupted interrupted or incomplete Windows Service Pack upgrade process;Corrupted interrupted or incomplete System Restore operation;Corrupted interrupted or incomplete Windows Automatic Updates shutdown configuration process;Corrupted interrupted or incomplete Windows Automatic Updates restart configuration process;Corruption of essential Windows system files by enabling compression to increase HDD free space;Accidental deletion of essential system files;Underpowered Power Supply Unit (PSU);Incorrectly installed Random Access Memory (RAM);Incompatible RAM;Incorrectly installed graphics card;Incorrectly installed expansion card;Internal devices incorrectly connected to the motherboard;Incorrect motherboard jumper settings;Basic Input Output System (BIOS) corruption;Incorrect device IRQ (Interrupt Request) settings in BIOS;Bad hard disk drive (HDD) sectors;Physically damaged HDD;Motherboard solder points short circuiting on a loose screw or a misaligned motherboard mount.
Aug 04, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
Will not start up all the way just keeps saying the big m then blur on and off slowly
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jul 21, 2011 | Motorola Cell Phones
My son downloaded virus and I got the blue screen of death. I ordered OS disks and got error that install could not proceed due to a missing file.
simple solution would be when running the os disk reformat the whole pc before continuing the install also after bios boot i would suggest seeing if you have a recovery partition usually activated after the bios by hitting f10 or f11
Mar 15, 2011 | Gateway...
Hey, when i power on my laptop it loads....then the screen just goes black. But It Is Still powered on. Please Help
Not positive whats wrong
butMy niece had same problem can you get into safe mode? if you can
go to safe mode run ANTIVIRUS immediatly
if you cant try this turn off then reboot the whole time hit F11 til welcome screen then type in administrator leave password blank if it lets you in fully run antivirus then do disk check and disk clean up and defrag dont leave till these are finished when fully done reboot then let disk check run when done it will go to welcome screen see if it lets you in should if its a glich or virus
I hope this helps and works for ya good luck
Mar 18, 2010 | Lenovo 3000 N200 0769 Intel Celeron 530...
ZOOSTORM CELERON 15IN DESKTOP freeze and monitor not detected
Can be a lot of things but most common is a virus corrupted file or operating system. Reinstall the OS or take it to someone who can possibly isolate the offending file and replace it.
Jan 07, 2009 | Computers & Internet
Laptop problems
hi
possibly ur system has a virus or a spyware.
visit www.donloads.com
go for "AVG" it usually comes for free.
also go for some anti ad ware and spyware(can be found on this site also)
run a whole system scan
if there is no virus found then i am afraid u hav to reinstall ur OS.
in any case do let me know.
Hitesh
Jun 22, 2008 | Sony VAIO F360 Notebook
Gateway 832GM PC Desktop Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
