Home | Reddy | Heater-30-55,000 BTU Variable | Need thermocouple par...
Reddy Heater-30-55,000 BTU Variable
Problem for Reddy Heater-30-55,000 BTU Variable
Need thermocouple part number
By n50xx on Oct 27, 2009
need thermocouple part number
Solution #1
posted on Oct 27, 2009
Not Rated)
billyvangogh
Rank: Guru  Air Conditioners  Expert
Rating: 90%, 25 votes
Pretty much any generic thermocouple should work...as long as the length is long enough
Was this helpful?
Yes
No
Popular Solutions for Reddy Heater-30-55,000 BTU
Questions and Unsolved Problems for Reddy Heater-30-55,000 BTU
Do you recommend Reddy Heater-30-55,000 BTU Variable?
Answer
Answer
The heater starts fine, but the gas flow is significantly reduced after a few seconds. Tried a... (More)
Answer
Tries to fire but shuts down after a few seconds. I have already ran it a few times this week. Now... (More)
Answer
Turns on with flame and fan and after 5-10 seconds shuts off. When I plug it in again, the same... (More)
Answer
my heater will fire up and run then if i unplug it and plug it back in the motor spins slow and the... (More)
Answer
55000 btu kerosene heater I ran great until i moved the heater to another room, plugged it back in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Reddy Heater-30-55,000 BTU...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
