Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
Problem with my tv
shared by 2 users
posted by yacoub12345 on Jan 01, 2008
the problem with my tv is that there is a red and green ghost at the bottom of the tv.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Kevinsul on Jan 08, 2008
I bought a brand new 42 inch Samsung plasma tv PS42 - QTHD about a year ago. I've hardly used it, but now, when i've been watching it for about 2 hours around the screen in different places large blue hazes or ghost like looking things appear. Its worse when its dark on screen. I've tried all the screen protection option but no look. Only thing that helps is if i turn the tv of for about an hour, but when i turn it back on after 2 hour it appears again. please tell us what you can cheers Kevin.
Solution #1
posted on Mar 10, 2008
Not Rated (0)
crikett
Rank:Wiz Wiz
Rating: 84%, 62 votes
Kevinsul,
If your information is correct on the type of set you have meaning Plasma, you might have a defective display panel, in that case check your warranty on the plasma display (pdl). The other side of the coin could be a x bottom left or right panels. If I were working on it I would scope the y and z sustain panels for proper waveforms. I wish there was an easy answer for you but there isn't.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on problem with my tv:
I don't want to Accept this solution
Solution #2
posted on Jan 24, 2008
Not Rated (0)
TTM77
Rank:Master Master
Rating: 79%, 59 votes
The ghost might be fix by replacing the stk chips. I posted the instruction in here http://www.fixya.com/support/t209258-panasonic_pt_47wx53_g
For Kevinsul, I believe this same chips over heat which degrade it's performance. When U said things, if you mean like spots then I don't believe it is this chip. But if you mean long strips ghost or lines then it's likely this chip problem.
Thank You!
Can you Help with these Projection Televisions problems?
Panasonic PT-53TW53 53 in. Rear Projection...
i have a 60 inch hitachi tv and i was watching it then all...
I have a Panasonic PT53TW53G tv. It has a yellow then blue...
Have a panasonic pt-53tw53g just replaced the 392-110 with...
Whenever the TV there is a constant cracking sound. The...
panasonic pt-53tw53g unit turns on then shuts off after 30...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find Projection TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
