Good morning! I have a GE SXS Fridge/Freezer (Model # GSS20IEMD WW Serial MD258184) where the top half of the freezer is no longer cold and the fridge is slightly cold, but not ideal. I pulled the appliance out and vacuumed the coils behind it and I defrosted the appliance already, but that has not solved it. It is still running, all the lights are still on, but the fan in the upper part of the freezer is no longer blowing. It was serviced in 12/30/05 to replace central control board and in 3/3/06 to replace the fan motor. Is there anything I can do/ replace to solve the problem?
if the fan in the freezer compartment is not running theres a problem. verify power to the fan motor, if present replace fan motor. if not hopefully theres a wiring schematic/diagram so you could trace that circuit back to the control board and verify whether thats bad or not.. WR55X10942 -
BOARD ASM MAIN CONTROL
generally though if the fan by the compressor is running the fan in the freezer should also be spinning and have power.. by the way, it states in the parts listing that it is a dc motor WR60X10074 -
Motor DC Evaporator Fan
hope this helps, best of luck, ttfn
my ge side by side refrigerator keeps stopping for periods of time, ice cream melts and then its...
(More)
my ge side by side refrigerator keeps stopping for periods of time, ice cream melts and then its starts running again on its own. This is the second refridgerator of this type I have owned in the last three years, had the same problem with the previous one (only 2 years old). Why?
ge profile side by side - freezer nor refrig is getting cold - about a month ago the freezer had ice...
(More)
ge profile side by side - freezer nor refrig is getting cold - about a month ago the freezer had ice acclumated a the bottom - i reset the breaker - no water coming out the dispenser
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay...
(More)
first ice dispenser and water dispenser were slow to trigger, then stopped working with dislay blinking, then temperature display went blank and showed "HRS", now just blank and no cooling.
