Question about Whirlpool LSN1000LW Top Load Washer
Spin Cycle Problems / Noise
Hey Experts!
Our washing machine, a Whirlpool Ultimate Care II - LSN1000LW0, is giving me a hassle. The other night, as it entered spin cycle, it started making a horrendous knocking noise (almost like an "unbalanced load" knock). I re-adjusted the load and tried again......same noise. I ran to Sears in the morning and purchased a motor coupler (I had already replaced two in the past), but when I went underneath, the coupler was intact.
After rigging the lid switch to spin with the lid open, the inner basket spins very slowly and I am assuming the knocking is coming from the fact that whatever is trying to drive the inner basket is slipping (or whatever) and not engaging the basket for "full spin".
So, I am wondering what's the dealie-o. I removed the motor and pulled the drive shaft out. Everything "looks intact"....meaning I don't see any broken pieces or springs laying around, but obviously something is busted. That is what has brought me here. Can anyone offer some assistance?
  • Trying Steve Jan 02, 2008
    Ok. Pulled the gear case and opened 'er up. Half of the "Gear Spin" was shaved off. Ended up ordering the "Gear Spin" kit (part #285362), seal (better safe-than-sorry fix - part #3349985), and the gear oil (part # 350572). I already have gasket sealer .........;) .
    Looks like that'll do 'er!
  • Trying Steve Jan 09, 2008
    Repaired gearbox (transmission) with above parts and installed. Didn't work, motor coupler was just spinning like crazy. So, it may have been a combination of problems.
    1. After repair, I carried the gearbox around by the shaft - which may have pulled the clutch out. I had to re-seal the gearbox anyway (had a little leak), so I re-sealed the gearbox and made sure the spin gear was engaging. Then.....carried the gearbox by the BOTTOM. ;)
    2. I had installed the "Spin Tube Thrust Washer" upside down. This is the washer that sits on top of the clutch. It is correctly installed with the little tabs facing down toward the clutch and "in between" the opening of the "C" Retaining Ring and the little "loop" on the other side. Also, the "Brake Cam Driver", the plastic piece that looks like a big washer with "fingers" (part # 285790), sits inside the clutch with the "fingers" on the opposite side of the clutch spring.
    3. Instead of laying the washing machine on its side to install the gearbox (like I did to remove it), I leaned it up against the wall so I could install the gearbox without the "Spin Tube Thrust Washer" falling out of place and so I could line it up better. After the gearbox was installed, I laid the unit on its side again to install the motor.
    Machine is now fixed and catching up on almost 2 weeks of laundry! WooHoo!
    Master:
  • 619 Answers
Have notice some spring below or in the floor ? the drum basket need a balancer spring in order the drum will control it movement and soundless .available in any apliances center.
Posted on Jan 10, 2008
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The spin cycle for my
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSN1000LW Top Load Washer Logo
337 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
