Question about Perstel Symphony4U MP3 Player
It's not working!
I think my SUMPHONY4U has a virus. how can i get it out?
0 characters
1 Points
When I delete files from my Sansa with media player some files remain on the player, but I cannot see these files on media player or in Explorer, how can I delete these?
I think what you see as files are actually viruses and cannot be easily deleted and even if you delete, when you insert the player again, you'll still see them. So you need to scan for viruses with a good anti virus. After that you can now delete anything you want. Make sure the system itself is properly scanned for virus.
Feb 06, 2010 | SanDisk Sansa m240 MP3 Player
I have a 30 gb zune. Got all the updates loaded, turns on, charges everything works, but the music plays then there's a long pause and starts playing again. this is continuous.
I think you need to scan for virus with a good anti virus, then if possible, format it(but see if you could remove the songs that you already have to avoid the stress of getting them back).
Feb 06, 2010 | Microsoft Zune JS8-00001 Digital Media...
DVD Player Infected By Virus When Using Pen Drive
I think it is a DVD player with hard disk?
Look for an option to format the disk.
That way you can get rid of the virus.
Sep 12, 2009 | Panasonic MP3 & Digital Media Players
I think that my sansa e260 have a virus, which could be the solution?
Reset All
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
May 02, 2009 | SanDisk Sansa e260 MP3 Player
Sounds like you fellas have defective players. Try reformatting them if you can and see what happens. it will erase all your music on it so you'll have to load it back up. If it doesn't work, you might want to try returning them in exchange for another.
Jun 30, 2008 | RCA TH1101 MP3 Player
I-pod is not working
how can i unlock my apple ipod
May 19, 2008 | Apple iPod nano
My Player has gone weird
yeah right.. i think it has a virus..all you have to do is to scan it with an anti virus...or format your that you can use it again..
Feb 23, 2008 | SanDisk Sansa e260 MP3 Player
Old comp had virus
The best way to delete any unwanted content is to install and run the Philips Device Manager software from the product CD, and select the restore option.
This software is only compatible with Windows XP.
Viruses would not cause damage to the MP3 because they do not run any files loaded on to them
Feb 20, 2008 | Philips GoGear HDD075/17 MP3 Player
How to clear virus on sandisk mp3
plug into usb goto my computer mp3 player shows up as removable disc (usually drive F:) right click drive f: and click format (a quick format should work( Good Luck
Sep 23, 2007 | SanDisk Sansa e260 MP3 Player
Since it has no operating system, it isn't possible to get a virus. It is probably a hardware problem and the unit might need repair.
Jul 25, 2007 | SanDisk Sansa e260 MP3 Player
Perstel Symphony4U MP3 Player Logo
Top Perstel MP3 & Digital Media Players Experts
Are you a Perstel MP3 and Digital Media Player Expert? Answer questions, earn points and help others
