Question about Philips DSR704
'Welcome. Power Up' by AF
I am using the Philips DSR704 receiver. Here is my problem...
I get the 'welcome. power up' message.  Then, I get pass the 'aquiring setelite'.  After this, I am able to select and view any program.  However, after about 2 to 6 minutes, the receiver goes back to either the 'blue screen' or the 'welcome. power up' screen.
Please advice on how to fix this problem
  • 3 Answers
NEED A NEW HARD DRIVE
Posted on Oct 01, 2008
Philips dsr704 that has a tuner that is failing
About the only solution that I know of is to send it to a company called Weaknees. It's expensive but they do good work. The prices for various repairs are on their web site. If you don't have any other problems order the specific tuner replacement. If you have other problems, you might want to go for their "general fix" solution.
Nov 17, 2009 | Philips DSR704
Philips DSR704 stuck at "Powering up unit"
you can take the hard drive out and hook it up to your computer as a slave. a fix it, take out and reinstall.
Dec 24, 2007 | Philips DSR704
Phillips DVR Model DSR704...fan works, black screen, no powing up
the power supply is bad.
I had to same problem with mine after a power outage. Luckily I had a spare TIVO series 2 receiver with an identical power supply. Popped it in the busted TIVO and I am back in business.
Apr 24, 2009 | Philips DSR704
Owners manual & remote
I just downloaded the manual for the DSR704 (except fo the inside of the front cover which I now need).
I went to directv.com/manuals. It gave a list of the manufacturers of their recorders. Choose Phillips and then select the DSR704. It was very easy once knew where to go. Good luck.
Aug 18, 2008 | Philips DSR704
NO POWER
NEED A NEW POWER SUPPLY
Aug 06, 2008 | Philips DSR704
No Power
I'm having the same problem. Moved from one room to another and no nothing happening except the fan.
Jun 26, 2008 | Philips DSR704
DSR704 First Download
As far as I know, you can't, but I have a different solution.
These units don't need to call in, unless you order PPV. However, to get past that first "guided setup" call, which is nothing more than a test call, I'd recommend just taking it to a friends house to make the test call.
After that, you'll have to put up with the nag messages about not making a call, or hack the unit to make it not want to make a call at all.
Dec 26, 2007 | Philips DSR704
Phillips DSR 704 Problem
It could be the hard drive, it could be the unit. The first, and easiest step is to replace the drive.
Dec 01, 2007 | Philips DSR704
Picture on DSR704 gets 'blocky', loose audio at the same time
Check the satellite signal strength on different transponders. On mine, 16 ands 17 are intermittent as are a number in the 20s but only on satellite 2 (even if you switch the cables). It's probably a bad 2nd tuner.
The only fix I've found is to repeat the "guided setup" and tell it you have only one cable coming in. That will take tuner2 out of the loop.
Oct 25, 2007 | Philips DSR704
Stuck at "Welcome Powering UP"
It's most likely the drive. You can buy preconfigured kits or buy the software and hard drive and do it yourself.
You can send it out to CCS in Indiana and they'll test/repair what is necessary (if they can). Some of these units are very old and they aren't repairable, but they do their best and are very quick on turn around times.
Sep 22, 2007 | Philips DSR704
Philips DSR704 Logo
212 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
