Question about Nokia 5300 Grey Cellular Phone
NOKIA 5300 - no sound
The only way I can get calls is when my phone vibrates. Been thru all the menus and settings. Volume is on, I can hear the keypad tones..all the profiles are customized to have sound, but can't play any music or hear any ringtunes in the tones menu either. Tried everything!! Wanted to set it back to the factory restore but don't want to lose everything on the phone...any ideas?
  • 4 more comments
  • simespsb Jan 05, 2008
    Same problems with no sound (can hear the keypad tones), Factory reset does not work nor anything else for that matter.
  • Anonymous Feb 07, 2008
    I have exactly the same problem.
  • Anonymous Jul 21, 2008
  • Anonymous Jul 23, 2008
    i can receive calls and text messages only when it vibrates. I cant hear sound although my profile is activated and cant hear when play my music player. I can hear it only when i used the headset. What is the problem with my nokia 5300? any possible solutions please?..
  • ryanne2000 Jul 23, 2008
    hear any ring tunes in the tones menu either. But the headset is good, i can hear sound when i used my headset ..Tried everything!!
  • r_ebbs Oct 24, 2008
    me too, I have no sound unless I place it on loudspeaker or use the headset...very frustrating!
Thanks. It worked. The speaker cover had come loose and I snapped it back into place. Before that i did check the equaliser and the night before the settings and profiles. was going to chuck the phone back at the guy who sold it to me,
Thanks FIXYA.
Posted on Jul 18, 2008
I have the same problem. just open your back cover, press the bottom part, which is below the battery, you will hear a click sound. then everything is OK.
Posted on Jan 28, 2010
  • ? ? Jan 28, 2010
    I had the same problem after I dropped the phone. only through earphone I can hear the music player.
    solution is open the back cover, press the bottom part which is below the battery, then everything is OK.
Had the same problem. Had tried everything. Speaker was loose also Just removed the back cover and clicke phone shell back in place. Easy.
Posted on Jul 22, 2008
Had the same problem after I dropped mine - no sound. Took the back off, put it back on. Works again. Thanks for the help.
Posted on Dec 12, 2009
Only way u can hear ringtone if the equilezers are rised up...
try this.
Posted on Jan 02, 2008
The speaker on the back of the fone is broken go to ur mobile phone retailer an they shoud sort it
Posted on Jan 01, 2008
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
I got this info off of page 60 from your manual.
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Message Alert
“if unchecked will only vibrate when the ringer volume is set to vibrate”. Except that I always have my ringer volume set to vibrate (for phone calls) but don’t want the phone to vibrate when I get an SMS. So in the suggestion above, I’d choose ‘never ever ever…’, the middle option would relate to the current ‘unchecked’ setting, and the top option would relate to the current checked setting.
Jul 01, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Nokia 1600 - how do I increase reception volume on in coming call
while on the call use the right and left scroll button
Nov 10, 2008 | Nokia 1600 Cellular Phone
Can't hear or be heard
am it can be that your phone is on silent check the volume or you mic is broken and the speaker, you can buy it for 5 bucks on ebay, contanct me for help
Jul 10, 2008 | Nokia 5300 Grey Cellular Phone
Nokia 5300 xpress music mobile phone won't ring
did you going to settings and then to tones?
Jan 19, 2008 | Nokia 5300 Grey Cellular Phone
No sound
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
Sep 02, 2007 | Jabra BT250 Consumer Headset
No sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 5300 Grey Cellular Phone Logo
560 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
