Question about Aiptek MPVR Digital Camera
Earphone, Av out and Av in problem
Every time I turn on my camera it comes up with the message Earphone Av out or av in. It's supposed to do that when I plug something into it. I've already taken the battery, sd card out. Nothing works!!
  • CodyL1121 Jan 01, 2008
    Please Help!
  • 63 Answers
Plug into the offending sockets to see if that changes anything. If that doesn't help:
This video helpful:
Posted on Dec 05, 2008
Ou trouver le av cable chez un marchand sur la rive sud de montreal
le cable n'est pas un appareil photo specifique, vous pouvez utiliser n'importe quel cable video approprie avec connecteur RCA par exemple...
en supposant que votre televiseur prend en charge en composite sur RCA New 5 FT Triple 3 RCA to 3 RCA Composite Audio Video AV Cable
Jun 16, 2014 | Astak 2.4 Ghz Wirless Color Cm-818t3...
Jvc av 20420 no sound
Check and replace damaged component/s at the audio output section circuit. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 07, 2013 | JVC AV-20420 20" TV
Headset jack broke inside my samsung's hp-t4254 side panel. is that panel removable? how can i get that jack out?
Yes, you can replaced the entire side AV board or the earphone jack only.
Side AV board
Earphone jack is available at the electronics supply, you must bring the sample of your jack to obtain the right replacement. This require you basic knowledge on soldering and desoldering. More convenient for if you are going to replace the entire board.
Oct 08, 2011 | Samsung Televison & Video
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
What cord do you need to plug the ipod into the karaoke machine
This depends on the karaoke machine in question. Mostly the Ipod accepts a 3mm earphone jack and the karaoke is supposed to support the regular av in 2 pin jack. so all you need to do is get the single 3mm headphone jack to 2 pin av in jack. that should work perfectly.
Hope this solution has been helpful?
Dec 29, 2010 | GPX Karaoke Party Machine
I have a FujiFilm FinePix S2700 HD Camera, and I was in love with it. The quality of the pictures, the ease of use... until the other day when I went to plug the cable into the a/v port to transfer...
This just happened to our camera. The AV connector was pushed to the side, and the LCD stopped working. My daughter pulled the little metal AV connector back to the original position and the camera works now, but the connector is damaged. I'm sure I'll have to take it to be repaired. I hope it doesn't cost as much as the camera. How did you solve it?
Oct 17, 2010 | Fuji FinePix A800 Digital Camera
I can't change the aperture setting or time value in all (tv, av, M) modes - turning the wheel only changes the exposure compensation (-2 to 2) scale. Nothing else changes. I've read the manual a million...
Try this.
Turn the command dial on the top of the camera to [AV]
Use the [main dial] next to the shutter button to adjust the aperture.
The rear button that is round that is marked 'Av +/-' is the shift button. This controls the exposure compensation.
Could you be turning the wrong wheel?
Hope this helps.
Feb 25, 2010 | Canon EOS Rebel 2000 35mm SLR Camera
I have a mikomi ctv14440, and it is meant to be able to switch av so that you can plug in a game console,camera in the back.the problem i am having on both sets that i have just bought for my kids is...
The mikomi ctv14440 I have has a scart socket on the back. Plug in an scart to av phono adaptor which has an input/output switch. Set the switch to input and press AV on the remote control. Now you can use the mikomi ctv14440 as an AV monitor with suitable leads. Press TV on the remote control to return to normal TV.
Dec 28, 2009 | Televison & Video
My canon sd10 digital camera lcd balnk/black bu tphoto view in lcd ..lcd like screen bu photo not show in screen so i donot photo capture
Had the same problem with my SD10. The switch in the AV port sometimes gets dirty or corroded, and tricks the camera into thinking that an AV plug is inserted. This will turn off the screen.
To fix it, repeatedly insert and remove an AV cable into the port several times. This may help break off any corrosion or dirt that may be holding this switch open.
Nov 08, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Aiptek MPVR Digital Camera Logo
64 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
