Question about Hitachi 53UWX10B 53" Rear Projection Television
No picture and the power light is going on and off consistently
    President:
  • 4,402 Answers
The most common cause of no video is due to the vertical output section failing. If this is the case the TV will still have sound from the program that the TV is tuned to. If you do not have sound the TV may have a main power supply problem. To find out if the high voltage is still operating you can remove the rear cover and turn the TV on to see if the filaments in the picture tubes are glowing. A no high voltage problem will require some basis troubleshooting of the main power supply. In many of these TVs I find that the horizontal output transistor will short out and this will shut down the main power supply.
Posted on Jan 09, 2008
46 inch samsung TV cycles on and off, the standby light blinks consistently and shows no picture.
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 31, 2017 | Samsung Televison & Video
The picture has too much yellow but can't be fixed in colour balance
The problem is actually that certain types of florescent lights don't emit a consistent color through the power cycle. At times of lower voltage, they can turn yellow. What you are actually seeing with the yellow tint is that the camera happened to take the picture while the power was at the low point in the cycle, so the room was actually that color at the moment.
Apr 04, 2016 | Cameras
Samsung PS-50C91H 50" plasma no picture
If this set has a cable box, satellite box or even a receiver hooked up to it remove power from them and the set for a while and power back to see if a reboot cures this issue.
short of that someone who is willing and knows how to check things is going to have to look inside and test things, repair if not what I have suggested consists of replacing boards which can either fix the set or not and gets expensive.
Dec 06, 2012 | Samsung Televison & Video
Now the power shuts off consistently. Says on for a few seconds and the picture looks Ok but it powers down and powers up again on its own.
Tv "LAMP" LED light is flashing?Yes.Projection lamp might have to be replacing?LAMP been iside the tv like 1 1/2 or 2 years,tv used daily like 4 or 5 hours a day?Yes,replaced the projection lamp,will solved the problems.
Feb 14, 2011 | Samsung HL-T5676S Television
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Tv goes on and then picture and sound go off at same time....no consistent time interval.....sometimes the screen is not fully illuminated...sometimes when the picture and sound go off, the power light...
There are two common possibilities that are causing this problem, dying power supply due to bad DC filter caps, or shorting out backlight inverter board, you will have to do in-depth troubleshooting to narrow down the problem. Please read my guide see the pictures so you can decide if you will want to DIY repair or not.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 01, 2010 | Toshiba 32HL83 32 in. LCD HDTV
I have a Samsung LN40A450 LCD TV that is only a year and a half old. I am getting no power to the tv only a consistent blinking red light and a audible clicking/beeping noise. What needs to be replaced?
I will explain how to:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.(see picture below)
  • Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated (see picture below)
  • Replace the damaged capacitor with the same value that you can see on the surface of the capacitor. (In this step you need any soldering tool)
My advice: replace capacitors with higher voltage, like 10V replace with 16V or 25V will be fine.
Feb 01, 2010 | Samsung LN40A450 LCD TV
Dark image when taking pictures of sceneries
If the pictures show up normal on the computer then the back light for the LCD is going bad...
try to replace the back light..
thank u
rate me!!
May 24, 2009 | Canon PowerShot A550 Digital Camera
Digital camera Fine Pix
Does this happen all under the same lighting conditions, or in low or very bright light? If consistent light, do the pictures still seem faded or blurry on the screen of a computer? if so, the sensor might be damaged, and yes a new one. If they're ok (consistent) on computer screens, then the camera lcd might be loose or damaged which means its fine but give it away and get a new one if you can't handle shooting without relying on the lcd.
Sep 13, 2007 | Cameras
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
53 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
