Question about Sanyo DS24205 24" TV
What do I do.
My tv when we plug it in it makes a low humming sound with no picture or sound except the humming noise.
    Problem Solver:
  • 11 Answers
Is it in standby? Have you tried pressing channel buttons on the remote and the front of the set?
If that's not it, then you need to take it to a repair shop. Could be any number of things unfortunately.
Posted on Mar 28, 2008
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ... > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2 > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
My tv is buzzing & the sound doesn't come on when I change channels
I need a little more information. Does the TV show a picture? Do you have audio on some channels or no audio at all.
Is the noise you hear of a low frequency, i.e. low hum? One thing you might try is unplugg yo6r TV from the wall for about 60 seconds or so, plug back in and see if the problem goes away. if not contact me back with the info I asked about. thanks
Mar 03, 2015 | Samsung Televison & Video
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
My lcd tv makes a humming noise
Try removing all cables going to the TV except the power cord. Power on the TV and press mute. If you have any unwanted noise, then you have a defective TV and since it is new, you should get an exchange. If there is no noise with the A/V cables removed, then you might have hooked the source (cable box/DVD Player) into the wrong inputs of the TV.
Mar 14, 2009 | LG 42LG30 42 in. LCD HDTV
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Picture went out and all the tv does is make a buzzing sound
The horizontal output transistor drives a transformer that gives you the high voltage to light up the picture tube,either the transistor or the transformer have gone bad,sometimes both have to be replaced and sometimes the transistor fails for no reason by itself.Be safe and call for help if you are not familiar with tv service.
Sep 20, 2006 | RCA F32450 32" TV
Sanyo DS24205 24" TV Logo
75 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
