Question about Video Game Consoles & Games
Xbox360 connection can you connect through bt home hub using network link cable for my xbox or do need go wireless
  • Anonymous Mar 13, 2014
    My Home hub connection is being interupted by BT Fon
  • 12 Answers
Yes, you are able to connect your 360 using a hardwired connection. In fact, it is even faster that way!
Your BT Home Hub has two ethernet jacks on it, for use with whatever devices you wish to connect to the internet (in this case, your 360). Simply plug your 360's ethernet cable into the jack, and voila! You can now access Live. However, if you wish to host games over live, you may need to open up certain ports for Live to use.
The ports are listed at: http://support.microsoft.com/kb/908874
A manual for using and setting up your BT Home Hub is at:
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=16536
Near the bottom of the page is a link for the PDF version of the manual.
Posted on Jan 20, 2008
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
Connecting TLWR743ND to BT hub
I spent ages trying to use tp- as an ap client. tried every setting I could think of. Then........ Changed wireless security setting on home hub 3 to use JUST WPA2 not WPA/WPA2 and all worked. Give it a go. :-)
May 04, 2012 | TP-LINK Router TLWR743ND 150Mbps Wireless...
How to get an internet connection for xbox live
Hello award ward,
To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible
with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
michael34
Mar 09, 2011 | Microsoft Xbox 360 Elite Console
We cannot connect wirelassly
...I'm not sure on what your actual question is here but make sure you have a wireless network to connect to (you can buy wireless router and an internet service via any internet service provider- I use BT)
If that's not your problem (which i don't know what is) - then make sure your typing security WPA key in properly. (WPA key should be located on the back of your router/hub if that wireless hub got delivered by your current internet service provider). If your still having trouble contact your current home network manager (dad/mum/guardian/employer/lanlord) who has software to control the WPA & what it is).
Your xbox should have a network adapter already installed (device inside that allows connection wirelessly to a networks wireless router/hub). So that shoulden't be the problem (unless your xbox is broken)
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
How do i find my DNS settings to connect to bt home hub? thanx
sould be able to find them automaticly if you need to find them you nad find them using your pc by hitting start selecting run and type in ipconfig will giv you all the settings
Feb 02, 2010 | Microsoft Wireless Network Adapter Xbox...
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Xbox live connection
three is the network
connect and install three usb modem
connect xbox to pc with ethernet cable
then start right click my network places and go to properties in network connections right click 3 usb modem then properties then advanced, tick the box allow other network users' then okay
now connect 3 3g device turn on xbox and BINGO !
Dec 15, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
90 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
