SOURCE: Says: The type of print head is incorrect.
I received a suggestion from one of your techs to clean the gold contacts with distilled water using a cotton swab. It worked. Thank you.
SOURCE: The type of print head is incorrect, please install the correct print head
patchiepoops,
make sure everything clicks. canon is known for their ''slide and click fittings''
don von gideonberg
SOURCE: incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
SOURCE: cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
