When I plug in my Verbatim 160GB hard drive to ANY of my four USB ports, it won't connect. Only the blue light flashes (which indicates power), but it doesn't "boot". I can't see it in My Computer
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
I connected freeAgentGo through network to D-Link router with USB port. When I try to use seagate...
(More)
I connected freeAgentGo through network to D-Link router with USB port. When I try to use seagate manager - it says "no external drives found" although it is Z: How can I make Z: to be recognized by Seagate Manager?
My External Hard disk , Buffalo model minisatation is not detecting when connected to a laptop or a...
(More)
My External Hard disk , Buffalo model minisatation is not detecting when connected to a laptop or a desktop PC.
who can fix my 1 gb cruzer? It has a bent port and my dog chewed it a little. It lights up and...
(More)
who can fix my 1 gb cruzer? It has a bent port and my dog chewed it a little. It lights up and registers but no files or storage use are found.
