Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
No vacuum My Floormate has plenty of air moving, but no vacuum at the nozzle. When I turn it on, the filter hops up to the black rubber "intake", rather than staying in its spot. It seems to me that the intake should be in contact with the filter when the reservoir is installed. And I don't understand why the intake isn't closer to it, but it seems fixed there, almost an inch higher than the filter. When I remove the bottom reservoir and turn the h3000 on, I feel vacuum at the intake, and air blowing into the reservoir chamber in a strong draft from a blower opening behind the intake. But when the reservoir is on, there is no suction at the nozzle at all. It appears that the suction at the nozzle is solely powered by the intake pulling air out of the reservoir, which is in turn sealed fairly well to the duct at the back of the chamber. So how can suction be developed at the nozzle, when the black rubber intake is not in contact with the filter at the top of the bottom reservoir? Has something slipped out of place? The reservoir is, AFAIK, in exactly the place where it has always been. And the rubber intake seems in place, also. Its housing doesn't look like it has moved at all. Thanks. Don.
  • WestofLB Jan 13, 2008
    Of Course! I dunno how I missed that, but after you suggested this, I went into the bathroom and found the spare part. Not "spare", but missing.
    Thanks a lot!
  • 126 Answers
Someone must have lost the filter cover from the machine. It is a clear blue plastic cover that goes over the filter and has a hole that lines up with the motor intake. It is approx. 3 inches square and has an angular top to coincide with the motor intake. Look around the house for it or order a new cover.
Posted on Jan 12, 2008
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
The vacuum does not pick up either dry or liquid. It seems like there is a loss of suction.
This is commonly caused by either a worn out squeegee on the nozzle, or a broken wheel assembly. To check the wheel assembly, turn the machine over and look for breakage where the assembly attaches at the rear. Another common problem is that the clear plastic cover over the filter has been misplaced. There should be a rectangular cover with a round hole in it covering the filter on the lower tank. Without this cover in place there is no suction to the pick-up tank.
Jul 26, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    Not picking up dirty water off floor.
    NORMALLY SUCTION PROBLEMS ARE CAUSED BY A POOR SEALING PROBLEM OR AIR LEEK. CHECK ALL BLACK RUBBER SEALS TO BE SURE THEY ARE SEATED CORRECTLY, NOT WORN OUT OR TORN. BE SURE FILTER AND TOP TO FILTER ARE IN PLACE, AND YOU MIGHT WANT TO LUBRICATE SEALS AND CONNECTION WITH A LITTLE VASILINE OR CRISCO IF YOU ARE A MOM LIKE ME. MINE IS WORKING FINE NOW, HOPE THIS HELPS.
    Feb 06, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
    Won't wet pick up
    the intake hose may be torn. remove lower tank and tilt machine back. look for the hose in the middle. Check for blockage in the nozzle and the squeegee condition. check filter cover to be in place.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
    Oct 01, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
    Troubleshoot floormate spinscrub 800 floor cleaner
    The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
    May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
    Hoover Floormate brushes won't turn
    With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
    Kirk Thompson
    San Juan, PR
    Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
    Floor Mate
    There is a black shaft with a black circular arm at a right angle to the shaft. The black plastic arm that sticks out of the front ( farthest away from the hinge) of the roller assembly plugs into the circular arm so that moving the scrub/vacuum slider causes the roller assembly to move up and down. I can do it with my finger, or use a flat blade screwdriver. I'm assuming you mean the black plastic thing with the little rollers on it.
    Kirk Thompson
    San Juan, PR
    Sep 03, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
    Hoover Floormate has lost most vacuum capability
    Check to make sure that the filter cover is in place. This is commonly lost or misplaced. It is a clear-blue plastic cover that lines up with the motor intake and acts as a link for the tank.
    Also, check the squeegees and make sure they are not torn. If they are, they will not allow the suction to concentrate in the nozzle. Also, check the black plastic wheel assy under the machine. These are notorious for breaking at the pivot pins at the back and this will not allow the machine to sit on the floor properly and will contribute to this problem.
    Jan 17, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
    Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
    138 people viewed this question
    Top Hoover Vacuums Experts
    Jim Parker
    Jim Parker
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
