FixYa.com
Tags:
Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 Frozen (by 4 users)
posted by Dorset1 on Jan 01, 2008
My Asko is frozen and I can not get the dishwasher to respond to ANY control.  I have turned off the circut breaker yet the problem does not resolve itself.  Any ideas on what to do?  Is there a reset button?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by 0011, posted on Aug 04, 2008
I have a problem with the Asko 1805. The problem was caused when the drainage was blocked. When unblocked, it drained the water out but now all the lights just blink. It seems to be frozen. Is there any way to reset this machine or any other ideas?
Comment by Guest, posted on May 11, 2008
I have an Asko 1475 SS. All lights are flashing - will not respond to any direction- therefore I have shut off the circuit breaker, but it does not reset, it continues to flash and the machine is trying to drain. However there is not water in the unit. HELP!
Comment by Guest, posted on Mar 18, 2008
Dishwasher Type:DW95.F1 has stopped its operation for 2 weeks but the lights on the panel is still flicking. we hsve checked everything and belive that something is wrong with the timer
Best Solution
posted on Jan 28, 2008
FixYa! (100)
Timon90
Rank:Guru Guru
Rating: 86%, 73 votes
Sounds like the controlunit is bad.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 05, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This is a common problem with the Asko1805. The machine is equipped with overfill protection. Water has leaked through to the bottom pan and has triggered the overflow shutoff float. You must get the water out of the bottom of the dishwasher. Unscrew the kickplate and the metal cover to access the bottom of the machine where the pumps and motors reside. Use a sponge to slop up the water in the pan. Blow dry the bottom. The machine will reset itself as soon as the water is gone.
This problem is often caused by poor drain pump action between cycles. If the pump has completely removed all water from one cycle and the next cycle adds more water then the dishwasher "floods" and triggers the overflow protection. I have found that 9 times out of 10 the problem is with build up or blockage where the drain pump connects to the sink drain. Keep this clean and your problem should disappear. The drain pump could be faulty but stick with the simple stuff first. Occasionally the drain hose may fall off the back of the machine loosing its loop and thus creating poor pumping action.
I hope this helps
Can you Help with these Dishwashers problems?
Dishwashers
quiet parner 1 du1055xtpb3...
quiet parner 1 du1055xtpb3... Answer This...
Dishwashers
Model LD 1403 W!- 6
Model LD 1403 W!- 6 months old.... Answer This...
Dishwashers
Leaking from under the...
Leaking from under the... Answer This...
lights on control panel...
I may have opened the door... Answer This...
asko 1805 - all idnicator lamps...
all indicator lamps are... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
