Question about Onkyo TX-SR605 Receiver
Onkyo HT-SR750 Just purchased a new Onkyo HT system that connects to a Mitsubishi DLP TV via Dish Network HD and a Samsung DVD player. I've run the sound setup and can hear through each of the separate speakers. I get video from both SAT broadcast and DVD, but no sound whatsoever from any input source. I have HDMI cables only running from both SAT and DVD into the receiver, and then a separate HDMI cable running into the TV. Need some serious help since I've spent hours on this and nothing works. thanks, Tom
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Posted on Jan 03, 2008
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it...
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Apr 03, 2011 | Onkyo TX-DS777
I have the Samsung HT-C550 home theater system and a Sony 42" HD TV. The two devices work well when playing a DVD but when I watch TV I can't get the TV sound through the home system. I am...
Try this:
Purchase a 3.5 mm jack (it will have a smaller connnector going into the TV and Red and White connectors on the other end).
Pull all the other cables running into the Blu Ray player out so that you are only left with the HDMI Cable coming from HDMI Out (DVD) to HDMI/DVI In (TV), along with the 3.5 jack.
You will be able to play the TV sound through the system.
Jan 13, 2011 | Samsung HTC550 Theater System
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Connect dvd/vcr to HD-tv via dish network
Hey my nameis Mike Houston of DISH Network and I see where you want to run the SanyoDVW-6000 DVD/VCR Player to the DISH Network receiver. You can run the SanyoDVD/VCR directly to the TV and pick the channel you want to record and it willrecord the channel showing.
Dec 07, 2010 | Sanyo DVW-6000 DVD Player/VCR
What is the best audio configuration with this setup?
You can't just plug in optical cables. Both the TV and amp have to be adjusted to allow the different type of signals to pass. I have an Onkyo receiver myself and you have to set the sound type up for each input. It's a bit tricky to do without a manual, but you can probably download one for free if you have lost yours.
Mar 12, 2017 | Onkyo HT-S5100 Theater System
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Connecting an a/v receiver to a Dish network receiver
DO you have manuals for all the units listed?
If not , try the Samsung consumer site.
It would take me quite a while to figure out your situation even with manuals and I have a business to run besides.
Also, ask some questions of Tech Support at Samsung..Let them KNOW how much you spent on their stuff.
God bless,
Jul 07, 2008 | Televison & Video
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Onkyo TX-SR605 Receiver Logo
291 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
