Printers
Problem for Printers
Generic problem for all Printers
Canon pro9000 Carriage lift mechanism err...
By viaujeff on Jan 01, 2008
I bough a canon PRO9000 Photo Printer and after 10 pages printer, I got 5110 error code. I guess is carriage lift mechanism error [5110]. The green and yellow lights are flashing 11 times and the cartdridges are not moving again. It was perfect before. I tried to clean up the cartdridges but nothing. Please help.
Same Problem
Apr 02, 2009
-   same problem as the poster-   Guest
Mar 17, 2009
-   Just installed Pro 9000 printer. Made about 4 prints then got this Service Error 5110. No reference to it in the manual. I will call Canon tomorrow.
-   Guest
Mar 04, 2009
-   after changing ink for the first time, my pro9000 started flashing green-orange back and forth. I went to the printer status in setting and it said I had an error 5110. Nothing I do changes this.-   Guest
Nov 12, 2008
-   Error Code 5110 after replacing ink cartridges. -   Guest
Sep 29, 2008
-   The online manual does not have this code listed, thus no resolution is given.-   Guest
Best Solution
posted on Jan 05, 2008
Helpful)
mater478
Rank: Guru
Rating: 87%, 83 votes
hi i am a certified Canon repair tech for this printer. this machine has a service bulliten for this problem and i have preformed the repair of this problem. the carridge lift cams are rotating faster then they should due to the wrong grease being applied to the part at the factory. this will require a Canon service center to repair because they is a special grease that needs to be used to slow down the cams. the best way is to contact Canon at 1-800-OK-CANON to locate a service center near you and they will repair the machine under the warrenty. hope this helps.
Was this helpful?
Yes
No
Solution #2
posted on May 05, 2009
Somewhat Helpful)
hopeful fixe
Rank: Apprentice
Rating: 75%, 1 votes
I am not a tech.  I don't guarantee anything.  It just worked for me.  Here is what I did.  uNPLUG THE PRINTER.  The covers on the Pro 9000 are snapped on so locate the slots that look like a flat screw driver will fit.  Insert the tip of the screwdriver and lift on the covers and they will come off.
Now, looking at the printer from the front, on the right side you will see a group of white gears with a black gear at the bottom.  The black gear has a 'flag' that us used by the sensor right there.  If you spin the white gear that is second from the top, it will lift the carriage to the hightest position.  Leave it at that position.
On ther front edge of the area where the printhead slides from the right side of the printer to the left and back, you will see a small switch that is a safety switch that stops the printer from moving the print unit back and forth.  I taped it down temporarily so that the printer thought the cover was on.
Next on the left side about 3/4s of the way down where the printhead would move to the left, you will see a small sensor looking up that sees the bottom of the print unit.  Lay a piece of paper over that sensor so that it is in the shade.
BE CAREFUL and keep your fingers out of the printer.  Plug the printer in and depres the power button.  The printer shoud first cycle the paper feed area.  Then, BE PATIENT, the ink unit comes to life and continues on its initiation.  It should slide to the right and actually tap the frame once, then do the same move, but tap twice.  Then after a bit, the left ink cartridge will light and the carriage will move to a sensor on the left and it will light up each cartridge, then it will lower the carriage for a second, then slide completely to the left and then the right.  After several more girations, it will put the carriage where it belongs.
That worked for me.  Good Luck
Was this helpful?
Yes
No
Solution #3
posted on Jan 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Barf
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
MP 620 printer is it a good buy
Answer
konika minolta 1600 magicolor
Answer
Powers up OK.Loaded a new cartridge which normally does a printer test. Did not do this and I cannot... (More)
Answer
I have broken the blue latch that holds down the cartidge in place. can I get this piece?
7 Other Users Have The Same Problem - Continued
Comment by foto shop, posted on Jun 10, 2008
I BOUGHT THE PRINTER A FEW DAYS AGO. I PRINTED ALMOST 5 PAGES AND THEN IT STOPPED PRINTING AND POP AN ERROR WITH THE NUMBER 5110. I REALLY NEED HELP WITH IT BECAUSE I HAVE A STORE AND THE PRINTER IS NEEDED HERE. PLEASE HELP ME.
Comment by OllieC1961, posted on Mar 07, 2008
My printer is flashing 12 times. I've tried the solutions suggested in the manual and it hasn't worked. The lights on the ink cartridge are not on.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
