Question about Cozy (W352E) Heater
Thermostat fails every year
I have a cozy dual sided wall heater and every year my thermostat needs to be replaced. I have tried millivolt only thermostats and that does not solve the problem. Should I just stock up on cheap thermostats or is this a known problem?
  • warrentaylor Jan 01, 2008
    Well, that may be true but I've have the mercury type thermostats in this long collection and they fail as well. The only difference is that COZY has recommended a millivolt ONLY style of thermostat. Previously I had been using the combo type. For the millivolt style, my choices are more limited and for the last 2 years these are 'contact' style. It just seems odd that every thermostat I've every had for the last 8 years has needed replacement the following year.
    Sergeant:
  • 288 Answers
The term "you get what you pay for" applies here. Get a thermostat that at least has a mercury bulb style. the cheap contacts or points style may just need to be cleaned each year. The digital seem to be the best, but there is no need to go over board either. Keep it simple.
Posted on Jan 01, 2008
  • Rob Luna
    Rob Luna Jan 02, 2008
    The contact type thermostat usually can be solved by cleaning off the points on the contact. As this is a milli-volt heater, it means just that, its less than 1 volt usually .750. So it doesn't take much to break the path of electricity. During the summer and fall months when the heat is not being used, a layer of dust and or grease can accumulate in the contacts where they meet. A cleaning with a small file, emery cloth, or even fine grit sandpaper will do the job removing the stuff that is preventing the current from going through. Or you can just do as you said and stock up on some thermostats, they are inexpensive compared to the other types. You didn't say if you tried a digital one. The heater itself is a pretty simple system. I don't know of any other part that would cause premature failure of the thermostat, if that is what you were wondering.
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
I have a Cozy double-wall heater model number W505D and I am not able to turn it on. The pilot is on but the thermostat does not seem to to turn on. The thermostat is new so I doubt that it is...
make sure you have a millivolt stat and not a 24 volt stat should have a MV on the stat, you can pull the wires off of stat and twist together to get the unit to turn on if it does wrong stat.
Dec 11, 2010 | Cozy (W352E) Heater
The thermostat broke & I cannot find a replacement that works. My Cozy is Model # CDV255 Serial # 91101102 Thank you, Hanya
Have to have a millivolt thermostat have to go to a heating wholesaler for this part a 24 volt stat will not work
Sep 20, 2010 | Cozy Heating & Cooling
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
Cozy Heater will not turn on from thermostat in the morning
no more than 20 feet of statr wire allowed and make sure the stat you have is for a millivolt system.
Dec 03, 2008 | Cozy Enclosed Front Console Heater 70,000...
My Cozy heater does not respond on the thermostat control
Make sure you have a stat that is for a millivolt system, if the stat you have has 24v on it wrong one, need to purchase at a heating wholesaler home depot lowes do not carry them.The stat should have mv for millivolts on the box or stat.
Nov 23, 2008 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
211 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
