Dell Inspiron 1525  PC Notebook
Problem for Dell Inspiron 1525 PC Notebook
There is power to Laptop but has a black screen
By tony_shelbou on Oct 27, 2009
There is power to Laptop but has a black screen and nothing happens at all, is there anything i can do?
Best Solution
posted on Oct 27, 2009
Very Helpful)
bhagyavichar
Rank: Guru  Computer Hardware  Expert
Rating: 95%, 2362 votes
itz may b many internal hardware cause, like the battery(main/cmos); ram; sm section of the system board; ccfl; inverter circuit; or even the lcd....
so itz always better to hv supervision..frm ur system admin/vendor/good or authorised service center....
Was this helpful?
Yes
No
9 people thought this was helpful
Solution #2
posted on Oct 30, 2009
Somewhat Helpful)
spiky3
Rank: Master  Computer Hardware  Expert
Rating: 79%, 7 votes
it could be there was a windows update that was unsuccessfully installed when you turned it off. (that leads to corrupted windows). Try accessing windows advance boot options (tap F8 on dell logo screen) .select repair your computer and use system restore (restore it to date where it was still working) hope this helps.
Was this helpful?
Yes
No
Solution #3
posted on Nov 03, 2009
Not Rated)
yohilz
Rank: Apprentice  Computer Hardware  Expert
Rating: 75%, 1 votes
I had the same problem with an Inspiron 1521 that was given to me. Turned out the only problem was that the RAM was installed incorrectly. Somehow I remembered that the memory needs to be installed in the correct slot for it to work. Meaning, if there are 2 slots available on the laptop, then the larger of the RAM would go into Bank-A and the smaller into Bank-B. If not done this way, you'll usually get power (sometimes none) and blank LCD. It's easy to make this mistake with these laptops because one bank is hidden under the keyboard and not as easily accessible as the one on the bottom of laptop. The #1 or "A" slot for my laptop happened to be the one under the keyboard. It had a 512MB chip installed while the outer one (#2 or "B" slot) had 1GB. Switching them did the trick for me. =) Check that out and see if maybe it was something as simple as that. It could save you a lot of grief and money. Hope this helped. =)
Was this helpful?
Yes
No
Solution #4
Not Rated)
jennifer720
Rank: Guru  Dell Computer Hardware  Expert
Rating: 88%, 159 votes
Hello and thank you for using Fixya's services.
You can test the laptop by plugging another monitor into it. If the monitor shows, then your screen is out (backlight or invertor). You can order a replacement screen through eBay for a very reasonable price.
If it doesn't appear then your video graphics card may be out. This can also be purchased and replaced.
Please let me know if you have any questions.
Was this helpful?
Yes
No
Popular Solutions for Dell Inspiron 1525 PC
Questions and Unsolved Problems for Dell Inspiron 1525 PC
Do you recommend Dell Inspiron 1525 PC Notebook?
Answer
Answer
Push start button, on light comes on, hard drive light flashes for few seconds, lights flash across... (More)
Answer
how to reset the system clock on a dell 510m tried it in tne bios they light up but wont alter,, if... (More)
Answer
blank screen curser in uper left hand corner
Answer
how to download or upload funny viedosor pics to my cam
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Inspiron 1525 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
