Panasonic PT-47WX53 47 in. Rear Projection HDTV Television
Phantom horizontal upward-scrolling lines... from a...
shared by 5 users
posted by HiDefDad on Jan 01, 2008
I have had a Panasonic PT-47WX53 rear projection HDTV for about four years now, and all has seemed fine up until this past week when I got a PS3 for Christmas. I only have DVI for a digital input on the TV. I had bought a $100 DVI-to-DVI cable about a year or so ago, to use with a Hi-Def cable-box at the time. However, my cable-service provider told me that they had not enabled the use of that output on their boxes, but I kept the cable anyhow in the hopes that that would change. It didn't.
Anyhow, somewhere in between then and now I also picked up a $20 DVI to HDMI adapter end for my expensive cable, to update it (as everything is now all HDMI, including the PS3) so I wouldn't simply LOSE the hundred bucks I had invested in it.
So when I got the PS3 last week, I set all the settings on both it and the TV (correctly, because I get picture and sound) for using the digital DVI cable with the HDMI adapter.
The problem is, after trying out a few Blu-Ray movies, I noticed a few horizontal "ghost" bars scrolling up my screen. They are not as noticeable when there is a bright image pictured on the screen (which is probably why I did not see them at first) but whenever the screen is predominantly darker, these bars are obnoxiously present. I checked some of the other inputs on the TV (antenna, component, etc.) and I DO notice a similar but far more faint image that I would almost never have seen if I had not been looking for it.
My question is threefold:
1. Is this a form of electromagnetic interference?
2. If not, then what is it?
and
3. How do I fix it (cuz it's bugging the crap out of me)?
Comment posted on Jan 02, 2008
Here is a pic of the bottom left corner of my HDTV screen with a shot from the "The Guardian" movie trailer. As you can see, there are phantom lines (#1 is more apparent than #2) running horizontally. They scroll up the screen slowly from bottom to top. In this shot they did not appear as strikingly as they were just two nights ago, so I'm really wondering if they are not a product defect, but the result of some form of EMI (which could change in magnitude from one day to the next)...???
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Posted by recall33 on May 09, 2008
I have the same problem, I have a phillips 55 in. rear projection hdtv
Posted by Guest on Apr 11, 2008
the image show like little points on the screem, how i fix this knowing that my tv resolution is 1080i?
Posted by Guest on Feb 26, 2008
I have to say that I also just recently started getting the horizontal light redish or purplish hues that scroll upwards. I had a tech come outto service and he says that it is the cable. So now cable company will be coming out.. Hopefully that all it is..
I dont see the line when i play dvds or the ps3
only cable
Posted by len firm on Jan 10, 2008
i have a mitsu 53-2 inch rear projection hdtv and i have had it for three years and i had noticed the other day the exact same thing you were describing i came online to see what i could find and here it is not the answer but the problem i dont think it has to do with the ps3 but i wonder what it from and how to fix it it is driving me crazy i do (did) have the dvi hooked up but not the hdmi help
Best Solution
posted on Jul 08, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
unplugging my cable box worked for me!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Phantom horizontal upward-scrolling lines... from a PS3 with HDMI to DVI:
I don't want to Accept this solution
Best Solution
posted on Feb 28, 2008
Helpful (85)
twentyways
Rating: 90%, 3 votes
i just unplug my cable line when playing my ps3 and the lines go away
Thank You!
Solution #3
posted on Oct 21, 2008
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
Change the resolution from 1080i to 720p, like uncheck the 1080i box dont even use it. only use the P ones 720p or 1080p.
Thank You!
Solution #4
posted on Jan 26, 2008
Shuttle83
Rank:Wiz Wiz
Rating: 85%, 740 votes
Hello All,
This problem is called hum or more correctly 60Hz-120Hz Hum it is caused by a partially open or an open filter capacitor in the power supply of the TV. This filter capacitors job is to filter out the 60Hz - 120Hz ripple voltage that is present on the power supply's output. When this cap fails the hum bleeds into the various stages and causes the lines that you are seeing on the video screen. To troubleshoot this problem you will need a schematic diagram (to locate the power supply test points and to get pictures of the correct waveforms that should be present), a signal generator (to generate a reference signal), and an Oscilloscope (to view the waveforms at the test points). What you will be looking at are the outputs of the power supply checking to see the level of the ripple voltage present on the outputs.
If you do not have this equipment nor an background in electronics, I would suggest that you take the Tv to a qualified TV repair facility to have it repaired.
I hope this helps,
Thank you,
Shuttle83
Thank You!
Solution #5
posted on Feb 07, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I am having a similar problem with a Hitachi HDTV rear projection, but when i disconnect the ps3, the lines are still there
Thank You!
Can you Help with these Projection Televisions problems?
Panasonic PT-47WX53 47 in. Rear Projection...
Lost manual..My freind gave me a Apex Dvd player.I would...
Is this TV High Definition? I have a Samsung Blue ray...
I need to know how to clean the mirror and adjust the guns...
I can not get the greens and reds to show up on my...
I just bought this tv used and it has double vision they...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find Projection TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
