Question about Akai LCT2721AD 27 in. LCD Television
Dvd will not play
I put dvd in it says loading and then opens I close again and it says loading again and then opens
  • Anonymous Feb 24, 2008
    Same thing - loading - I do not hear the disc spin up - and the the disc is being spat out again.
  • studgen Apr 27, 2008
    dvdplayer won't run dvd
Check the flat ribbon cable. It's a brown flat film cable that should lock into DVD mechinism. Make sure it's seated properly.
Posted on Feb 25, 2008
    Problem Solver:
  • 40 Answers
Dvd player is bad...you must order a new one...i dont know if it is available...but if it's under warrantee..then they must replace it or or the tv itself
Posted on Jan 27, 2008
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Cheers,
Jun 22, 2011 | Sony DVP-C670D
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
I put the disc in and then it closes and then opens again and i close it and it opens again. does it need to be cleaned or what?
itis unable to load the disc from tray to the spinning mechanism for playing or recording take it to the repairs there is an assembly problem or loading mechanism problem
Feb 20, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Will not play DVD Movies.
The Lense is dirty just open your dvd and get an eye pad, deep it in methylated spirit and wipe on the lense or just run a lense cleaner and put the dvd it should be able to play.
Dec 26, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Drawer closes by itself
The loading mechanism is off by a tooth or 2. The tray out position switch is not being triggered properly and the tray will reenter the machine. Did this just start happening? It is possible that the sensor switches are defective too. Worse case scenerio is about $5 in parts plus the local labor rate for repair.
Dan
Mar 28, 2008 | Pioneer HTD-520DV System
DVD tray will not open
I had the same problem - unplug first- it is easy to undo all 6 small screws - open it up -plug in and then you can give it a little help to open it. It worked for me, BUT now it will open and close but not play the dvd.
Jan 13, 2008 | Toshiba SD4990 DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
LG DVD/VIDEO RECORDER/PLAYER
First, the two of you Don't have the same problem. Now then, the unit that won't play DVDs needs an alignment or replacement of the optical assembly. The VCR unit has a bind of some sort in the carriage load assembly...accordianman
Nov 13, 2007 | LG V181 DVD Player/VCR
Keeps opening
may have a microswitch that signals that the door is closed that may be faulty. look for a switch that is actuated when the door closes.
Nov 06, 2007 | Emerson EWR20V4 DVD Recorder/VCR
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Akai LCT2721AD 27 in. LCD Television Logo
43 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
