Question about Toshiba 42H81 42" Rear Projection Television
Toshiba 46wh08b the screen on my tosh bends at top corners and i cant get the convergence to rectify the problem
  • statickitten Jan 22, 2008
    i try to use the ocnvergence but it's not working, the green color is the problem...
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 22, 2008
The screen bends and the colours separate in the bottom left corner.
This set uses two stk392-110 convergence chips.
If convergence WILL NOT ADJUST AND OR IS BOWED both chips and any of the 1.8 ohm protect resistors that are around them and bad need to be replaced.
This can be a do it yourself repair if you have some skill, total parts cost on EBAY would be under 25 dollars.
see attached photo of chips and what a typical convergence problem looks like.
If you are able to attempt the repair I can assist you.
If the photos and my solution here helped you rate this solution as "very helpful" as I do this here for free.
SD TECH
Aug 10, 2010 | Toshiba 42H81 42" Rear Projection...
Toshiba 43HX70 convergence problem
One or both of the STK convergence chips have probably failed.
I can give you guidance on this if you are confident to do the repair. I had the same problem with my Tosh 40WH08B and after replacing these chips it works like new.
May 21, 2009 | Toshiba Televison & Video
Convergence Problem
There is a convergence board located inside the set that regulates the alignment procedure. this board is malfunctioning and there is a chip set on the board that has failed. you will need to replace this board in order to restore proper convergence functions.
May 21, 2009 | Toshiba TheaterWide 46HM94 46" Rear...
Service mood
most models of tosh projo tv service MODE is mute on remote hold that down whilst pressing menu on tv letgo both press menu again
you get an s
use channel up or down and vol up dn to scroll/adjust
enter 7 on remote to enter convergence fine tune.
Mar 03, 2009 | Toshiba 61A60 TV
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
Red gun on sony projection tv is distorted bends up in the top corners and down in the bottom corners.can't correct with the convergence controls, or flash focus.
you will need to replace the two convergence ICs and a couple of the pico fuses. Please respond to this same post with your model number and I will assist you further with the problem.
Aug 03, 2008 | Televison & Video
Problem with tv
If your Model is Tosh 43H71,then pull chassis and locate F850,
F851 soldered-in fuses...check with meter..if open,replace with
proper value micro fuse(s) and solder jumper wires 008,010,017,
048,600 located on signal board.Replace convergence IC's
STK392-110 with IC's from kit # X 480295 ( upgrade )...........T.
Mar 31, 2008 | Toshiba 43H71 43" Rear Projection...
Green convergance goes out when tv warms up tosh projection tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
STK392-110 replace with STK394-160
STK392-120 Hitachi replaces these with STK394-160, for other sets it may not be a good sub. They have been fine in the Philips sets so far.
STK392-150 replace with STK394-160
***The 394 series replaced the 392 series and is cooler running. The subs listed here are the ones that I know to work in most sets.
· http://www.mouser.com/index.cfm?handler=home
· http://www.mcmelectronics.com
· http://www.bdent.com
· http://www.electronix.com
Feb 20, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 46wh08b projector television
Doug, convergence circuit is failing, involves removing one of the boards, replacing the convergence IC`s and probably a couple of burnt resistors, not a "layperson repair", requires soldering experience, accurate voltmeter to find the bad resistors, etc. I would suggest calling a tv tech for this repair, questions? e-mail me back BMW Rider
Jan 09, 2008 | Toshiba 46HM95 46" HDTV
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
