Question about Toshiba Satellite M65 Notebook
Toshiba M65 will not boot
This is the second time this has happened. Last Christmas I powered the unit down and took it with me out of town, on the second day it would not boot up. The fan would come on for afew seconds, the cd/dvd drive light would flash for a few seconds then it would shut back off. I replaced the mothercoard and it has worked for exactly a year. This year I did the same thing powered it down and took it with me. Got to my destination and same thing. I'm positive it is charging so it is not a battery problem. I removed the cover off the hard drive, it does not spin nor the head move. I cannot believe the motherboard is bad (again) I've re-seated all the normal parts (not processor as yet). Do you have any suggestions???
Thank you,
  • 2 more comments
  • pwdby460 Jan 02, 2008
    Yes I tried that, no good. Thanks though. Toshiba wants $35 just to get support. I'd hate to pay and not actually solve the problem. Most support techs just go by a book they have. Anything out of the ordinary I've found them to be useless.
  • Ken_in_Chad Jan 02, 2008
    I have two M65s. We are missionaries in Africa and the day we left the states to come back here my wife's wouldn't boot. I brought it anyway since there was no time to do anything. I swapped everything from the other computer with no luck. Bad mother board! Replaced under warranty, came back sound didn't work, Sent back for another board. In the mean time the other one failed with the same problem, light comes on for a few seconds. Not under warranty so i took it apart to reseat things even cpu, no luck. Put in the closet for a few weeks. The first one fails again, same problem. I keep the fan and fins clean with compressed air. It never gets above 80-85 degrees in the house. This one still under warranty but we plan to return to the states in a few months so will bring it then.
    I took the other one out of the closet because i read something about hitting the power button repeated times. It came on the first time I hit the button. I shut it down to put it back together and it worked fine for about two weeks but i didn't shut it down or let it hibernate. I tried the first computer and it started again also after several minutes of hitting the power button and worked fine. Again i disabled hibernate and standby. We got a new computer and decided to send the one back for warranty with someone so i had to shut them down to swap the hard drives since they were in the wrong computer. This only took a few minutes and then nether one would come back on. It has been weeks now and I can't get either one going now.
    We plan try to get the one replaced since it will be the third time returned for a mother board. I will not spend $300 on a mother board for the other one unless i am sure they have solved the problem. I can buy a similar machine new for about $700 on sale with duo core etc. Then there is the problem with Vista of course.
    If anyone knows of a recall or an updated board i would be very interested to find out. Almost all of the laptops that our organization uses are Toshibas and although some live in areas were they are operating at over 100 degrees we haven't seen this problem with any of the other models that we have.
    Sorry this is so long but i thought that it might be useful to some. It is definitely a mother board problem. I did notice with the one machine that for several days in the morning it did not want to boot right away.
    This is the condensed story! LOL
  • pwdby460 Jan 05, 2008
    Hi Bear,
    Yes, I've tried another hard drive. No good. I also tried my hard drive in another computer it booted part way, then locked up on a driver initialization. So the drive does work. I hooked an external monitor up and it flashed a few times before the 'puter shut back off. I'm wondering if it is the video part of the motherboard not initializing. I'm going to take it all apart and re-assemble this weekend and see what happens. Kind of frustrating it being my work computer.
  • wmdfh Feb 12, 2008
    I have the same problem now. I can not boot up my laptop (Satellite M65). The power button has blue light on for a few seconds and then goes off. Sometimes, fan runs with the light at the begining, sometimes, fan does not run at all. I do not know what to do. Please help. Thanks.
Usually the capacitors on mobo for voltage regulators are bad. Replace all 4 of them and you're happy for a while :)
Posted on Apr 09, 2008
I started having the shut off problem in spring of 06. I thought I had some virus, looked online and everywhere. One site suggested the grounding was bad to the monitor. I disasembled and reasembled, problem fixed......until, it dropped about 2 weeks ago.....problem resurfaced......I'm disasembling right now.
Posted on Jan 15, 2008
  • 239 Answers
Do you have access to another Hard drive you can try. I have a feeling its your hdd, I had a problem like you are talking about and found it to be my HDD I replaced after I tried a friends to see and it works. Presto it works, Thank the Computer Gods LOL Hope that gets you going again. Take Care Now. Bear001
Posted on Jan 02, 2008
  • bear001 Jan 04, 2008
    Did you get a brand new mother board the first time because, The problem thats been happening may be a bad or faulty part made from the factory and the never fixed it They just hope that the part don't go bad while the computer is under warranty and if it does its much cheaper to fix than to have a recall. So what I would suggest doing is finding A remaned board that has already had that problem and its been fixed with a good part that won't fail, So thats all I can suggest that, or Keeping a fan on it all the time, But that sounds rediculous Hey, Ok I sure hope you all get that problem fixed, And I sure am sorry that You all are having problems. Take Care bear001
Toshiba Satellite laptop will not boot. Shows power from outlet and battery but no indicator light is present for the last two in the five light sequence.
Its an old trick that got my Dell laptop working
Unplug the laptop remove the battery press the power button,...nothing will happen, wait a few seconds put battery back in laptop plug it in hold upside down press power button until it boots
If that doesn't work it could be a bad/loose/dead bios battery What is the model of the laptop?
May 11, 2011 | Toshiba Computers & Internet
Hi, i have an Toshiba Satellite M65-S9092 with XP installed. everything still stock inside but operating system, had vista when we got it. this laptop shuts down at random times... no booting down, just...
I realise that you have checked the fans for operation, but they could still have a build up of dust which stops them from cooling efficiently, the main fan blows air through a heatsink and you can often get quite a build up between the fan and the heatsink. If this is not the case, or clearing it doesn't work, check your event viewer for any recurring errors, instant shutdown could be faulty ram, faulty hard drive or the heat problem.
I hope this helps
May 05, 2011 | Toshiba Satellite M65-S9092 Notebook
Tried to reset bios password by removing internal battery. Nothing changed. It's a model L505 GS6000 and it's only 6 days out of warranty. Toshiba says they are not going to help me without charging me!...
Hi Friend, I understand that your Toshiba Motherboard is not releasing the password even after removal of CMOS Battery. Well, to resolve this issue, I would suggest you to power off your system completely by unplugging the power form the main socket on the wall remove the battery and short the two contacts of the battery socket for 3 or more seconds and release the short. Now, wait for 10 or more seconds and reinstall the battery in the socket and see, your problem is resolved or not. If not, please get back to me.
Dec 18, 2010 | Toshiba Computers & Internet
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba M65-9062 Turns on but won't boot up.
Go here:
This may solve your problem without replacing the MB.
Mar 31, 2009 | Toshiba Satellite M65-S9062: M65-S9062...
Will not turn on, no lights at all
Try to remove the battery, and plug it into the wall. If it then boots, your battery has failed. This happens frequently. If it still wont boot you will need to take to someone to see if the board has died or other issues. Hope this helps
Nov 30, 2008 | Toshiba Satellite M65-S9063 PC Notebook
Toshiba Satellite M65-S821 WONT BOOT UP
probably shorted out motherboard. same happened to mine. motherboard alone is over $300 plus
Nov 07, 2008 | Toshiba A205-S4577 Notebook
you didn't list what you did do, so you might have already tried this, but I think it's always a good idea to try re-seating the RAM and then try different RAM in the computer if you can. The symptoms seem to be identical to those caused by bad RAM sometimes. It might also be a heating or fan problem which, when detected by the motherboard, activates an auto shut down.
Also, make sure the power supply is producing the proper amperage and consistent voltage. some power adapters provide a signal to the computer, along with power, that is critical as well, so there is a slight possibility that the adapter may be causing the problem. Actually I'd follow this further. If the battery is almost dead and the adapter not working, those are the exact symptoms you'd get. Do you know if the battery is charged and the adapter works?
I'm assuming you've removed all external devices and cards or other ad-ons.
Did you try taking the battery out, unplugging it and pushing the power button 5-10 times? This might help reset some settings.
And, if you already have done any of these, please list them so people, like me, don't waste our time giving you incorrect answers, because you didn't take your time to list what you've done.
Google it first. because look what popped up.
Nov 07, 2008 | Toshiba Satellite M65-S821 Notebook
Toshiba Satellite M65-S909 laptop will not start
Based on the problem you have described it could be one of many issues as to what is causing the problems. I know that answer doesn't help but need to be up front with you and not list all the possible issues. What I can tell you is that our company would be able to diagosis the problem once at our nationwide repair garage. If your interested in using our company check out our company website at Take a look at the testimonal section to see that we do quality work. I
Jun 01, 2008 | Computers & Internet
Toshiba Satellite A35-S159 Shut down
If it does the same thing when it's plugged in, it might be time for a trip to the service center.
Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite M65 Notebook Logo
482 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
