Question about Dryers
Kenmore dryer 110.66812690
Spins fine, but won't get hot. Replaced heating element, cleaned vents inside and out. checked wiring. still not hot. ?????
  • singlemomof3 Dec 18, 2008
    kenmore electric mod 110.66732500. turns on does not heat up. blows out cold air
Kenmore dryer 110.66812690 won't get hot blowing out cold air.
Posted on Sep 04, 2008
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Feb 17, 2015 | Dryers
Why dose a electric kenmore dryer 70 seires the dryer runs about 1minute then turns off
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Jun 22, 2014 | Kenmore Dryers
Kenmore gas dryer won't get hot
gas--- glo bar that lights the gas is bad or the vent to the outside is clogged electric-----wire may be burnt off the heating element or element has to be replaced
Jan 14, 2013 | Dryers
Kenmore elite model 11062952100 My dryer will not heat I replaced The thermal cutoff and high limit thermostat the dryer produce heat briefly but is not producing heat again.
There is a high limit switch (looks like a button with two wires hooked to it) on the bottom of the vent frame. When the vent fills up with lent at the bottom it gets hot. For safety, this limit switch will turn heat off. Remove the vent frame and clean it out and check the continuity of the switch. Also, make sure both heater elements are working properly.
Jun 19, 2011 | Kenmore 63942 Dryer
Dryer spins, air flows through vent but isn't hot
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Sep 15, 2009 | Whirlpool LER7646E Dryer
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Dryer gets hot and spins won't dry cloths
clean exhaust vent ASAP it could start a fire if the heat has nowhere to go out the moisture stays inside and your heat element will cycle on and off on a high temp limit swich
Apr 01, 2009 | Kenmore 73952 Gas Dryer
My Kenmore Elite dryer spins with no heat
please check the thermal cutoff. these are the parts with 2 thick wires attached to it. they are normally located near the heating element ( if electrical ) and (near the exhaust if it is gas).
these parts control the heating element.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Kenmore 73952 Gas Dryer
Kenmore gas dryer does not get hot
hi. thanks for the question .check the thermal fuse, at the back inside the dryer. remove back panel .thermal fuse is on the air duct , a small piece of plastic with 2 blue wires to it. replace the fuse also clean all venting .thanks the appliance doc
Oct 05, 2008 | Kenmore Dryers
Dryers Logo
326 people viewed this question
Top Dryers Experts
