Question about Panasonic PT-53WX42 53" Rear Projection Television
Tv pt-53wx42f willnotturnonredbuttonon&offnopicture
  • santos muniz Jan 01, 2008
    whereislampionlyseethe3colorlensonrear
  • 790 Answers
Try removing and re-installing the lamp cover on the back.
may be the lamp cover is not seated properly causing the safety switch to not engage all the way, when the lamp cover heats up and expands, it fall away further from the switch tripping it, shutting the set down.
when you remove and re-install the lamp cover, after you take the single screw out, tilt the cover out and forward from the top about 3/4 of the way out and then tilt it back into normal position and put the screw back.
Posted on Jan 01, 2008
  • Kanth raj
    Kanth raj Jan 01, 2008
    ITS A VERY COMMON PROBLEM!! JUST CHECK THIS LINK HOW MANY PANASONIC USERS HAVE THE PROBLEM
    http://stafford.typepad.com/the_next_ame...
  • Kanth raj
    Kanth raj Jan 02, 2008
    lamp is in the small door in the rear on the t.v, just to the right and
    up a little from the fan secured with 2 screws...its where the cord to
    plug the t.v. in comes out.
PT-53wx42f won't come back on. Red light blinks several times, checked cords, all are ok. Is there a reset button to press?
Please replace 2 chips in tv, these are marked (location number) as IC7001 and IC7002 on circuit board and number written on both big black chips is same that is STK392-110
Click PartStore.com to buy 2 chips and get it replaced in tv to solve the issue.
Thanks.
Jul 30, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-53wx42f no sound
Pls go to the audio menu with the panasonic remote and be sure the speakers are on........you may also want to un plug and plug back after ten min to reset the tv. You may want to reset your cable box the same way
Jun 02, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42F does not turn on, gives single flash code
my tv had the same problem and the B+140 was low. When I measured it, it was 89volts unfortunatly led me to the Flyback tra$former. after alot of troubleshooting work, I realized that the primary is short circuited. Also the horizontal output xsitor heats up alot on start up, thankfully it doesn't blow :)
I've had panasonic flybacks do this before to me. I havn't replaced my Flayback yet but when I pony up the $65.00 I expect (and pray) the TV to work fine. There is an off chance that something like the splitter or the foucus block caused this failure, but I doubt it.
Jul 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Jan 07, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT= 53WX42F
Does it blink three times if so its a convergence problem -your set uses stk392-110 i usually replace with stk392-150 or stk392-180 these are more stable. if you have no soldering experience or electronic experience. but if you want the challenge go for it. remember that there can be several thousand volts in this set even when unplugged.
Dec 12, 2007 | Panasonic PT-56WX53 53" Rear Projection...
Real projection tv model# pt-53wx42f
you need to replace (2) STK392-110s some are 120s 150s up grade to 180s.Also after you replace them you will have to do complete alinement of convergence in order to do this you must have service codes.
Dec 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
