924 Fuser Error - Open circuit detected in thermistor circuit. The thermistor provides feedback on the temperature of the fuser roller and when it fails, the fuser normally does not heat up.
It means either disassembling the fuser and replacing the thermistor ( if you can find one) or replacing the fuser assembly. so i would suggest that take it to nearest service centre of lexmark. best of luck
I have a Fuji Xerox Docuprint 203A and have just changed the toner cartridge but the toner light is...
(More)
I have a Fuji Xerox Docuprint 203A and have just changed the toner cartridge but the toner light is still on. Managed to print a few pages after a lot of button-mashing but once again, the light popped on. Now it simply won't print anything...I've tried opening the front cover then turning it off and holding the reset button, etc (which worked before) but it doesn't work any more! Please help!
sir, i'm not able to power on my canon ip1980. when i plug on the printer the power stays for just...
(More)
sir, i'm not able to power on my canon ip1980. when i plug on the printer the power stays for just one second and after that, it getting off.. what should be the possible reason for this???
My HP 3700dn has been fine for a couple of years, but recently has started to mis-align the...
(More)
My HP 3700dn has been fine for a couple of years, but recently has started to mis-align the background of powerpoints or frames/lines on spreadsheets ... the text prints in the correct place .... so this ruins the print jobs any idea of cause, and resolution?
Have a Lexmark T430 that jams with first page partially out of exit and second just before the...
(More)
Have a Lexmark T430 that jams with first page partially out of exit and second just before the fuser. Happens intermittently and pops 200 and 202 errors. Cleaned all sensors, feed roll and reseated connectors. Stumped!!
