Home | Samsung | Pleomax PKB-7000X (00807575012977) | Am having trancend 4gb...
Samsung Pleomax PKB-7000X
Problem for Samsung Pleomax PKB-7000X (00807575012977)
Am having trancend 4gb pendrive when i insert into
By ashish_wayka on Oct 27, 2009
am having trancend 4gb pendrive when i insert into usb drive i got error as"windows cant recognise usb device due to malfunctioning" .even i insert in my friends comp error get repeated
Best Solution
posted on Oct 27, 2009
Helpful)
techman007
Rank: Guru
Rating: 90%, 85 votes
Unfortunely the device has malfunctioned and need to be replaced.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
bob_computer
Rank: Guru  Computer Accessories  Expert
Rating: 87%, 1181 votes
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Was this helpful?
Yes
No
Solution #3
Not Rated)
Geekman
Rating: 85%, 1659 votes
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Was this helpful?
Yes
No
Popular Solutions for Samsung Pleomax PKB-7000X
Questions and Unsolved Problems for Samsung Pleomax PKB-7000X
Do you recommend Samsung Pleomax PKB-7000X (00807575012977)?
Answer
Answer
I am on a Imac computer. The keyboard does not reboot up after it sleeps for a while. IS there a... (More)
Answer
I am Litu .I use Samsung Omnia Windows mobile for internet.... mobile to pc. But when i cannected... (More)
Answer
USB modem is malfunctioned not able to recognized my pc, pls help immediately
Answer
I have a problem with pleomax pwc 7000x installation where the systems sats that I can't pass sort... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung Pleomax PKB-7000X:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14697
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
