Problem for Scooters
Generic problem for all Scooters
?Thermocouples need replacing
?Thermocouple problem. Removing them out of the loop appears to fix the problem of worsening & persistent shutdown after short distances on a slope or grassy terrain (goes well on flat).
They are screwed onto the frame 2 inline with 2connection screw posts each for + & - lead connection .
Run with 2 x 12V batteries currently using 55AH, though the machine is supposed to be able to use 38 or 55AH with no mention of any change-outs.
No part numbers, but the sheet metal plate inside reads (P?)A223-40. Anyone know where replacements might be obtained??
thanks.
Popular Solutions for Scooters
Questions and Unsolved Problems for Scooters
Looking for a scooter for my dad, I saw the RTO Buzzaround Lite scooter, if any of you guys out...
(More)
Looking for a scooter for my dad, I saw the RTO Buzzaround Lite scooter, if any of you guys out there have any experience with it, I'll be happy to hear your opinions on it.
230 chauffeur doesn't charge.No movement on the Amp gauge to show charging. Batteries new and fuse...
(More)
230 chauffeur doesn't charge.No movement on the Amp gauge to show charging. Batteries new and fuse in charging unit under seat good. Can plug in and the horn works like current running straight to horn
i have a pride legend classic xl8 and the spline drive from the motor to the diff has snapped, where...
(More)
i have a pride legend classic xl8 and the spline drive from the motor to the diff has snapped, where can i get a new one or do i have to get a new rear axle complete?
beeper sounds as soon asyou press forward or reverse will not drive brake engaged tthis is the same...
(More)
beeper sounds as soon asyou press forward or reverse will not drive brake engaged tthis is the same sound if you tried to move with the brake disengaged.
I have an Elite Traveler Plus. The batteries are dead. I plug in the charger and the light ...
(More)
I have an Elite Traveler Plus. The batteries are dead. I plug in the charger and the light indicator is green (saying charge is ok)? but the batteries are still dead. Batteries have been drained for a couple of months. Why doesn't the red indicator light come on indicating a charging sequence?
