Question about RCA R52WM24 52" HDTV Projection Television
Double vision and no convergence
Double vision and no convergence to adjust it. it is a RCA R52WM24 52 in. HDTV
  • 6 more comments
  • Dorito Jan 03, 2008
    I have the smae Tv with same problem
    Rca said its not covered under warranty I bought in 8-06
    these Morons,Anyway yesterday the tv jus went black then
    it looked like a 3D Movie,Double my Cable info is all warped,its a total
    Bummer I mean I dont know What to do,Dude
  • arynsunn Jan 04, 2008
    Thanx i was able to find the fuse and it is blown, but i was wondering where you can buy the fuse link and if maybe you knew a part number for it? All I see is 396, and the rating (T400ma).
    Oh Dorito if you look on the bottom left side in the tray you will see a large black transformer. Just to the right of it are 3 tiny red rectangles, those are the fusible links. The one he mentioned (FL231) is in the center, and should read a rating on top of it for 400 ma.
  • arynsunn Jan 05, 2008
    Yeah, I couldn't find that exact fusible link so my brother who works with electric and electronic equipment is going to use a different fuse. But I dont suggest doing it yourself if you dont know how to solder the fuse to the circuit board. I suggest finding a friend or someone who knows someone who has eitheir worked as an electrician or anything in electronic repair like computers, vcrs, game systems etc. They would more likely know what they are doing and might do what im gonna do.
    So I'll let you know if using a different fuse works.
    Oh I wouldnt pay that much for labor because the fuse is less than 5 dollars. So I would try to find someone who could help you or who would fix it for a lot cheaper.
    Ok just for the record we used a 500 instead of the 400 and it worked so the tv is fixed thank you leadtech for your help and good luck Dorito. i'll keep in touch to see if you were able to fix your tv.
  • dewey64 Mar 20, 2008
    I own the same RCA Projection TV (Model R52WM24). The TV was working fine this morning until I turned it off then back on only to find 3 lines across the TV (red,green and blue)
    Now the images on the screen are appearing three times each one in the red, green and blue.
    Is this the same Convergence Problem and can it be fixed by changing the FL231 fuse?
  • jrmfairbanks Mar 24, 2008
    We are having the same problem with the 3 lines and the 3-d look. Where do I get the part to fix is and is it something that the average person can fix. We have had this tv a little over one year. Thanks.
  • Art Sep 06, 2008
    Having the same picture problem, 2yrs. 1 day after buying it. i hope your solutions work, it sound better than anything I've found so far.
  • 3 Answers
I had the same problem. Thanks to the many posts on this site I was able to deduct that it was the Fusible Link F231. Was able to purchase them at Part# 576-3960400000 Littelfuse Fuses - A 125V UL TL LL .400A . They are only 55 cents plus shipping. I bought 5 for under $10 shipped. Only took 2 days to get them. Replaced it (needs to be re-soldered to board) and TV works like a charm!! I couldn't believe it. What a lifesaver!! Now I'm set if the fuse goes again...
Posted on Feb 01, 2008
  • Babylooch Feb 02, 2008
    I had the same problem as Arynsunn and Dorito. I was able to find and replace fusible link F231 and it worked for 2.5 days. Today, turned the tv on and the fuse must have blown again. We want to replace the convergence IC's, but cannot find them. Other posts show big (2 x 3") IC's on the back of heat sinks, but there is nothing that looks like that in our tv. Can you point us to the convergence IC's in this TV (RCA R52WM24)? Thanks so much for your help.
  • 192 Answers
I have found that fusible link FL231 is the main cause of this problem. It's located by the high voltage transformer and looks like a square coil.
Check it with an ohm meter and if it checks bad, then, replace it and you should not have to realign the convergence.
Any questions or comments, respond to this post and I will reply.
Posted on Jan 01, 2008
How do i find and change this Link?
I mean I opened her up and theres jus Tons Of Wires I felt stupid.I mean should i Just Call A repair Man
I dont know if its worth it.
Thanks B4 hand Guys
Posted on Jan 03, 2008
  • Dorito Jan 05, 2008
    Thanks arynsunn i looked but i couldnt figure it out so
    called the repair man $345.00 cash 375 tax
    crazy man i dont know if its worth it any suggestions?
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
My RCA HD52W59 HDTV Television has double vision and red, green and blue colors separated like a spectrum in stead of all the colors blending together to make one uniform picture. What can I do?
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 09, 2010 | RCA HD52W59 HDTV Projection Television
Double vision
Its usually caused by a failed FL231, DL231 and CL230. You can get the repair kit from called the ITC222 & ITC222A convergence option missing repair kit. The kit contains the parts and the CD with instructions.
Jul 09, 2010 | RCA HD52W59 HDTV Projection Television
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
My RCA projection TV is showing double vision
You can get the STK730-130 convergence IC at the following link which should take care of that issue. Its 24.00
Jul 12, 2009 | RCA P52920BL 52" Rear Projection...
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Double vision..
Adjust the convergence in the menu. If it will not adjust then solder connections on convergence ics or ics themselves need replaced.
Apr 26, 2009 | Televison & Video
Double vision tv
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double vision pretty much
This problem from what you are describing is a convergence issue the customer menu has a option that might help set convergence. if that doesent work a technician may have be called to adjust convergence or see what part has failed in the convergence cuicit
Feb 18, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
808 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
