I just replaced the 2 capacitors that was causing the "Please Wait" problem. Now, it only powers on from the unit and the remote won't work, and the other buttons on the unit won't work either.
I assume you put the caps in the right way? Check to see if you accidentally bridged a solder joint. Or I've done this, pull other components out to check them and got them turned around backwards, especially caps.
Ever since the time change, my E85H has been acting flaky. I did get the clock re-set, but now it...
(More)
Ever since the time change, my E85H has been acting flaky. I did get the clock re-set, but now it randomly freezes up. When I hit the Direct Navigator button, the display on the front of the machine shows it going to the NAV mode, but the display on the TV screen just goes to black, and the only way to get out of it seems to be to re-start the machine. If I hit Time Slip during playback, it brings up the preview window, but not the window that shows the number of minutes to advance, and it won't go out of this mode, again, without restarting the DVR. Resetting the Guide (channel up/down) seems to clear it temporarily, but it's back to misbehaving within a few days. Also sometimes when resetting the guide, it comes up in bizarre colors and won't let me clear out of it without unplugging the unit. Any ideas? Thanks in advance for any advice you can give me.
my remote says check remote3 how do i fix it since every time i touch it . it won't allow me to do...
(More)
my remote says check remote3 how do i fix it since every time i touch it . it won't allow me to do anything?
When placing DVD in it says no read Also wont burn disc And makes a clonking noise when trying to'...
(More)
When placing DVD in it says no read Also wont burn disc And makes a clonking noise when trying to' read DVD hard drive still records ok
Hello, ever since the time change on 10-31 (central time) our DMR-E85H recorder will not record at...
(More)
Hello, ever since the time change on 10-31 (central time) our DMR-E85H recorder will not record at the programmed time we have set. Please advise. Thx
