Question about Belkin N1 Vision Router
How to forward website to belkin n1 vision router
Hi
I am use belkin n1 vision router
my website ping to our Belkin Router
I create website in my LAN
how to forward it
  • 37 Answers
Do static IP to the network card in the PC
example 192.168.2.15 you choice from you lan
then from the web PC check you IP
http://whatismyip.com
or from command line netstat -a or ipconfig /all
once you obtain the true ip od your web computer
in port forward you forwared the ip address external obtained from whatismyip.com
this is asuming you using port 80 with apatche webserver/ or widows iis
The lan card in the webserver needs to be static
Posted on Oct 27, 2009
    New Friend:
  • 55 Answers
You would have to log into the router to configure port forwarding on port 80. You would have to know the IP address of the computer hosting the website and put that in the routers config under port forwarding.
SOURCE:
Hi i am using Belkin N1 vision version 102uk when ive plugged this in to the sky adsl router, it is showing no router detected?? can you help?? regards chris
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
Aug 03, 2010 | Belkin N1 Vision Wireless Router
Slower throughput having gone to talk talk
That is there way of saying they don't want to support that router or don;t want to accept their network is having trouble. If you do get another router and still have the same problems then they have no excuses.
Jun 26, 2010 | Belkin N1 Vision Wireless Router
N1 Vision Router: i cannot connect to my belkin router...
Check the routers gateway IP address is in the same subnet as the other computers or laptop.
Ie 192.168.1.X . (X is between 1 and 254)
In addition, the sub net mask is 255.255.255.0
If all is ok then it is probably a miss configuration with WPA /WEP options
May 18, 2010 | Belkin N1 Vision Router
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
Belkin N1 Vision - Virtual Servers Add button doesn't run ok
Ascertain what incoming ports you need to open and the IP address of the device / computer that you wish to forward to and set the ports up manually.
· Enter a description for the service
· Enter the inbound port ranges from WAN
· Enter TCP/ UDP type
· Enter IP address that the service is to be forwarded
· Enter the private port range (keep these the same as the incoming ports unless you are running multiple services ie 2 web servers on port 80)
· Click enable check box and save entry
· Repeat as required.
Sep 27, 2009 | Belkin N1 Vision Router
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
How do i install my new belkin systyem when ive
yes you can use it.
first connect your Belkin router to computer with lan cable .
Then access it wityh this link.
http://192.168.15.1
user name as "admin" and password as "admin"or
blank or
"password"
then configure your router as your old lynksys settings.then save settings and restart .
Aug 22, 2009 | Belkin N1 Vision Router
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
How to port forward for microtorrent on belkin n1 vision
Here is a good walk-through how to set up utorrent on your router.
Enjoy!
PS: Make sure that utorrent is not blocked by your Windows firewall!
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 12, 2009 | Belkin N1 Vision Router
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 Vision Router Logo
307 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
