The open/close tray will not open. It reads open then close but does not open. It makes a groaning sound as if it's trying to open but can't. There was no warning of this. The display shows imput L2 and bye when turned off. I have tried to plug and unplug it several times. I have tried the select buttom repeatedly. I have tried both remote and manual buttons. I can open the door to the tray but still no tray comes out. vince fadale
Assuming there is nothing stuck in the tray, the gears over time will wear out and the tray will no longer come out. Another possible cause is a weak motor, either way the tray will have to be replaced in order for it to work properly again.
Either 2or more cd's are stuck instead of 1 Plus the motor which with interlinked gear's made of plastic/Teflon/HDPE keeps rolling but resulting is slipping of the gear teeth are making the sort of mechanical groans. Open the top byopen all the screws 6-8 of them and remove all the CD's piled up and offer a small prayer and close it and then give it another chance..........................sodeep
Was this helpful?
Yes
No
Popular Solutions for Panasonic DMR-E55 DVD Recorder
the panasonic dmr e55 will burn a disc from my video camera and play on the dvd player but no other...
(More)
the panasonic dmr e55 will burn a disc from my video camera and play on the dvd player but no other dvd player. and i read all the instructions step for step
component f001 230v 2ah seems to be a ceramic fuse that is faulty is this component and where can...
(More)
COMPONENT F001 230V 2AH SEEMS TO BE A CERAMIC FUSE THAT IS FAULTY IS THIS COMPONENT AND WHERE CAN PURCHASE A REPLACEMENT PART. I LIVE NEAR CREWE. POWER INTO THE BOX BUT NOT OPERATING THE PANSONIC DVD VIDEO RECORDER
I have recorded several chapters from a tape but would like to 'insert' a earlier segment in an...
(More)
I have recorded several chapters from a tape but would like to 'insert' a earlier segment in an appropriate location. Is that possible without erasing and re taping? (I no longer have my instruction manual) **** T.
