Question about Fuji FinePix E550 Digital Camera
Images are 'liney' whatever I do with them
Bought a re-con E550 and when taking pictures all the colours have lines going through them, espicially things in the background.
On black and white piccies it looks like you have taken the picture through a fishbowl with a set of blinds attached to the lens!
any ideas?
It's set to 6mp without raw
  • 3 more comments
  • kadody Jan 21, 2008
    same problem
  • Anonymous Jan 22, 2008
    Same problem with refurished E550.
  • rjpg Sep 01, 2008
    It sounds like I have the same issue. The camera is 3 years old and now the pictures are over exposed and have fine lines running through them. I have reset all of the settings but that did not help. I did buy an extended warranty from Mack. We'll see if it was worth the $20,,,
  • Anonymous Sep 23, 2008
    lines in picturwe
  • bwoloski Oct 21, 2008
    I had the same problem, I also had an extended warranty. I took the camera to Fuji, and they replaced the whole lens assembly. It was well worth the cost of the warranty. Ive had the camera four years now, and it still works as brand new, and I still have a year left on the warranty.
  • 423 Answers
From my experience (seen dozens of them like yours), the CCD (image sensor) has gone bad. There's lots on the 'net about this unfortunate phenomenon. In short, earlier CCD's were not sealed against moisture very well. Over time some seepage occurs (doesn't take much) causing streaking (usually purple & green) and blurred images. It may occur early in the camera's life, if used in humid conditions, or it may take a year or two or three in normal conditions. Copy and paste the following into your browser for some more technical explanations
Posted on Jan 22, 2008
  • Steve Grezoux
    Steve Grezoux Jan 22, 2008
    I forgot to mention that there is no fix, except for major parts replacement. If it's under warranty (or you have an extended warranty), it should be fixed at N/C. If out of warranty, enough jumping up and down at the service facility may persuade them to fix this "known defect" at little or no cost to you. They know of the defect, they just don't want to fess up to it.
It's not the memory card; tried a new one still does it
Posted on Jan 21, 2008
Printing liney and wrong colours
Faults like this would typically be down to a partially blocked/dried printhead and easily resolved with cleans. If however repeated cleans have not improved the situation I would recommend contacting Kodak directly. They should be able to help you to determine whether is is genuinely a dry ink issue or if it is a mechanical problem with the printhead (that are pretty common with this range).
Jan 29, 2013 | Kodak Esp 3250 Allinone Multifunction ( ...
Canon powershot a470 vertical lines, white picture, blurred
The image sensor is defective. There is no quick fix other than replacing the image sensor.
May 13, 2017 | Canon PowerShot A470 Digital Camera
Olympus X-42 less than 2 yrs old, hardly used. When switched on to take a picture I get a series of coloured (pink, purple etc.) vertical lines on the LCD screen and when I take a picture, the camera...
If the lines are on the images when viewed on the computer then its likely that the cameras sensor is the problem. This is a tricky part to get to as its the heart of the system. Might be time to get a new camera as replacing the sensor will be far more expensive ($150-200+) than a new camera. I had a look on ebay and they are going for less than $50 as they are an old camera now.
Ive replaced my Olympus with a Sony Cybershot W830, 20mp and 8x zoom, direct from Sony for $150.
Feb 09, 2018 | Olympus X-42 Digital Camera
Coloured scratches in the images
The lens maybe damaged due to high radiation. try repairing it by going to the shop were you bought it. maybe they will knoe the problem.
Jun 02, 2012 | Kodak EasyShare C140 Digital Camera
Sony KLV32T400A LCD TV. Colour Problem With Black colour of hair showing blue. Other than that the TV is fine. What solution
Hello, Sounds like an LVDS Cable or T-con Board.
Usually this will slowly get worse until it is repaired. It is caused by a failing T-con (Control) Board or connecting cable. T-Con Will Need replacement. This picture show's more extreme T-con board failures
Feb 18, 2012 | Sony Televison & Video
I was recently given the FinePix E550 by someone who had purchased a newer camera. I do not have the usb cord to download pix and my Dell 942 All-in-One will not recognize the camera card. What do I need...
The problem you are experiencing with your Fuji FinePix E550 could be down to a number of reasons.
You do not say the memory card size you are using but the Dell 942 will probably only read cards xD-Picture Cards 1Gb or lower.
It maybe a better idea to remove the xD card from the camera and use a USB card reader to take the images off the card. Alternatively you could buy a replacement USB cable
Hope the suggestions help.
Dec 29, 2010 | Fuji FinePix E550 Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Overexposure and vertical lines
My E550 started producing over exposed frames (everythings white except maybe across top) with lines.This just happens outside.On inside the pictures are great.
Sep 09, 2007 | Fuji FinePix E550 Digital Camera
Fuji FinePix E550 Digital Camera Logo
103 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
