1996 Ford Contour Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change a thermostat?? - 1996 Ford Contour
Anonymous
Level 2:
Scholar:
  • Expert 147 Answers
  • Posted on Oct 27, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
147
Questions
Helped
47461
Points
453
Buy the correct thermostat and thermostat gasket for your car, then locate the upper radiator hose. Where the upper hose connects to the engine there should be a two bolt hose connection/ thermostat housing ( could be 3 or 4 bolt, but most are 2) these bolts should be removed and then gently lift the hose and hose connection/thermostat housing exposing the old thermostat. note the position then replace the new thermostat just as the old was installed.
Matthew Boulden
Level 3:
  • Master 440 Answers
Matthew Boulden
Master
Level 3:
Answers
440
Questions
Helped
232715
Points
1524
You will need to remove the thermostat housing which is located in line with the radiator hose. It is normally the large upper hose that runs into the engine block that is connected to the housing. Remove the 2-3 bolts, the housing and the thermostat. Put the new one in and replace the bolts. That is all there is to it.
What size wrench do I need to change the thermostat on a 2002 diamante
Were is the thermostat on a 2002 mitsubishi diamante 3.5 v6 ...
www.fixya.com/.../t15150678-thermostat_2002_mitsubishi_diamante_3...
Nov 26, 2012 - SOURCE: asistance to change the thermostat in a 2002 mitsubishi ....size wrench do I need to change the thermostat on a 2002 diamante.
change thermostat change thermostat - Fixya
www.fixya.com/cars/t19454162-change_thermostat
Aug 16, 2013 - change thermostat - Mitsubishi 2002 Diamante question. ... What size wrench do I need to change the thermostat on a 2002 diamante. May 29 ...
Unanswered Mitsubishi Diamante Car and Truck -Q&A
www.dqrkc.com/cars/mitsubishi/diamante/problems
Mitsubishi Diamante - Unanswered Questions, Problems & Issues. Ad ... What size wrench do I need to change the thermostat on a 2002 diamante.
How to change thermostat on 2001 rav4
  • The thermostat on a Toyota RAV4 is located inside the engine coolant container. To reach the thermostat, open your hood and locate the coolant filler cap. Open the cap and then drain enough coolant so that the coolant level is below the thermostat housing. You should be able to identify the thermostat as a circular cap attached to the inside of the coolant container
Running hot...how doi change thermostat
the normal temp. from 70 to 90 deg cent., if it is in range do not change thermostat.
thermostat range from 92 to 82 so the cooling fan work on 92 and stop on 82 ,check it is written on thermostat.
2helpful
Need to change thermostat, any tips?
to change the thermostat follow the top radiator hose back to the block, remove the two bolts that go through the thermostat housing and lift it up, remove the old thermostat and replace a new one, including gasket. Make sure the engine is cooled down and the water drained before you remove thermostat. Most likely you have a 195 degree.
9helpful
3answers
The Toyota Camry engine light is on. Error Code P0125
Change bank 1 sensor 1 this will solve your problem. Tihs is a fuel issue nit a thermostat issue.
2answers
Can't get coolant flow after changing the thermostat
You will need to Change the Water Pump. It is still pumping, Just not enough to get the Thermostat to Open.
Changing a thermostat in a 1997 Oldsmobile Cutless
The thermostat is on the intake by the exhaust cross over. The crossover will have to be removed to get the thermostat housing out. If the intake gaskets are leaking fix them and change the thermostat while the intake is off. The only reason I say this is because the intake gaskets are a common problem.
6helpful
Follow the big water hose on top of the radiator to the engine blogk. Where it goes into the block there should be 2 or 3 bolts to remove the housing. When you change the thermostat you should also change the gasket. I hope this helps.you.
18helpful
2answers
2004 jeep liberty thermostat change?
ihave to change my thermostat in my 04 jeep liberty is it hard
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
