I have a Linksys router, WRT150N, and never had a proble, with it until now. It linked from my main PC to my laptop in another room and all of a sudden, it stopped connecting and I cannot get onto the internet with the laptop. I need help in trying to get this to work.
Don't need to reset the router. IF you reset the router you will loose the connection on the wired computer also. So your laptop is not able to go online. but your desktop is able to go online that means there must be a problem with the wireless connection.Check the wireless settings on the router. Click Here for step by step solution
With the wrt150n there has been reports of dective wireless althogh you may only need to turn off do a factory reset at times and check for a update verion of firmware .
When doing an update to a router it is a very good idea that you have a UPS battery backup in good working condition hooked to the computer and the router in case of a power spike or outage if you have problems from power during the flash you will have even more problems trying to recover the router I do this often relash routers firm ware trust me it is not somting to atempt with out a UPS battery power backup.
Less hope all you need to do is resset the router to factory defaults..
Router turned on
press and hold the rest button on back of router till lights flash 30 sec.
unplug the power on router
WAIT one min then turn router back on
Wait one more min. then hook router back up
you will need to reset all security if you have set wifi security
http:/198.168.1.1 then admin will alow you back in to router setup
I hardly ever set security on routers leaving them open has advantages if you live away from other wireless users .
If there is no wireles signal from the router then you may need to return for repair .
Remember it is a good idea to turn off router and cable modem's at least once every 30 days so they may renew their configuration and clear memory .when ever you notice a problem always turn the power off the modem and router first before doing any re flashing of firmware.this way you will know if theire is a true problem . never reflash or upgrate firmware unless you are having a problem somtimes newer is not always better.
I konw this is a long post yet I can not express the use of UPS battery power backup My self will not turn on my computer ore routers if not present.
you need more help let me know
I use the TP-LINK wireless router.About a week now it have been on and off and can no longer connect...
(More)
I use the TP-LINK wireless router.About a week now it have been on and off and can no longer connect to it at all.All the indicatior lights show its working and when i try to connect my laptop it connectes with limited connection and i also cant browse.I have tried using the reset buttom to reset it but still the same.I cant even login into the admin settings to do it again.
i have my xbox 360 in my room on the second floor and the router is on the other side of the house...
(More)
i have my xbox 360 in my room on the second floor and the router is on the other side of the house on the first floor. i changed my routers connection to N connections only. it barely increased. and i have looked for how to make a homemade antenna but i havent found one yet. do you have any suggestions?
you had said on a post: "I too had this problem and I hardcoded the mac address of my 360 into...
(More)
you had said on a post: "I too had this problem and I hardcoded the mac address of my 360 into the router and enbled no encryption, Im note sure but i think it might have been the security encryption causing it for me. I work fine now..." How did you do that? I have my router page up and I am having trouble navigating it and finding out what I need to change in order to do this-- Thanks!
