Question about Toshiba 50H72 50" Rear Projection Television
The bottom Circumference Convergence is WAY off and won't adjust
The bottom of my screen shows double pictures/words..for example...the scroll at the bottom of ESPN Football games is doubled..Bottom words are RED..the top word are at an arch and are GREEN. When I go to the Circumference Convergence Menu, the bottom numbers (7, 8 and 9) are WAY out of line and will not adjust. The number are OUT of the box. Top numbers are ok...middle numbers, 4 and 6, are slightly off. Make my New Year and tell me this is a quick inexpensive fix! Puhleeeeeze!
  • 205 Answers
This is most likely a convergence amplifier problem. The repair shop will charge you hundreds of dollars to fix it. If you're up to the challenge you can fix it for less than $50. If you search this site for "convergence" you will find lots of posts. Here's one I posted for another person with this problem and I offered a couple of links that should be a good deal of help:
http://www.fixya.com/support/t261950-43h71
If you have more questions please ask. This repair is not impossible, but if you've never soldered electrical components before it may be a bit challenging.
Lastly, I would like you to know that I don't get paid for this, I just like trying to help. If you find this information helpful I hope you'll rate the solution positively. Thanks and good luck.
Posted on Jan 01, 2008
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Screen plays double
It is called convergence out IC failure and you need to replace 2, ICs in convergence section of TV.
If you are familiar with TV repair or can solder electronics parts in circuit board then let me know exact model number of Panasonic TV to guide you more with technical info or call local TV repair shop for repair.
Apr 24, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Samsung HCL473W 1080i red shadow & words are curved at top/bottom
I believe you have convergence problem on your rear projector TV. It require to replace may be 2 IC output convergence or the convergence drive, after replace those component you need to readjust convergence which mean you move the RED GREEN BLUE to be 1 on top each other you must have the remote control and service manual to get into the service mode, if you thing you can get those part in your country the service manual I may help you with that, ask your husband if he like to challenge it. I hope that is give you some ideas
Cheers
Dec 17, 2008 | Samsung - Projection TV replacement lamp...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
60" Phillips HDTV Rear Projection
You need new convergence ICs two of them numbers STK392-110 they are available at the following link and they provide free installation instructions with pictures as well as free online tech support while you do the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
SCROLLING LINES AT BOTTOM OF TV SCREEN
need replace the capacitors at side of the ic vertical marked on the , init to the big first.
Jan 11, 2008 | Apex Digital AT2708 27" TV
The words on the screen is doubled or trippled.
Go to the picture control menu and turn the color to minumum so that you are watching a black & white picture. Do this to determine if the color offset affects the overall screen or just the lower corner. If the center is off, go to the convergence adjustment menu and align the red and blue onto the green as described in the owners manual. Some models also allow you to align the outer edges as well. If the bottom is still bad you may have a problem in the convergence circuit. If the outlines are not seriously bowed or distorted a minor convergence toutchup by a qualified technician should correct the problem, otherwise parts are involved and the repair is considered major.
Nov 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
RCA F27442 27" TV
1) Ask what the part location on the board is = IC301 for example..
2) Provide service #
3) Could be LA7612N
4) If they were not blowing smoke,why didn't they give you a
six digit RCA part # ??
....................................................T.
Nov 09, 2007 | RCA 32V420T 32" TV
My toshiba tn61x81 projection tv
have you tried the convergence option in the menu? i believe it is under "picture". this allows for nine different sections of the screen to be adjusted when projection images get out of whack.
Oct 20, 2007 | Toshiba TN61X81 61" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
