Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Problem for Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Why do vegetables freeze in the vegetable drawer?
By verosilver on Oct 27, 2009
why do vegetables freeze in the vegetable drawer? new problem in the past month. Temp setting has been constant for the past 3 years without problems
Comments:
Nov 09, 2009
- Thank you all for all your suggestions. My brother suggested that the cold air return/vent/intake might be blocked by crumbs or such things. He took the vegetables drawers out and the deli drawer out as well. He cleaned way back there with a damp sponge, removed crumbs and debris and lo and behold, no more frozen vegetables!!!!! I also had a container blocking the fan on the top shelf, and removed that as well. So which one was the culprit, I dont know, but I like not having frozen carrots and celery anymore.
Solution #1
posted on Nov 08, 2009
Not Rated)
Redpackman
Rank: Master
Rating: 0%, 0 votes
Have you put a good thermometer in the refrigerator, let it sit there for an hour or so without opening the door and then checked the temperature? If you're near 32 degrees, you've found the problem. Temperature uniformity is usually a problem in refrigerators...thus the fans, but ideally the temp should be in the mid 30's (34-38 degrees) rather than low 30's or you'll be freezing someplace
Was this helpful?
Yes
No
Solution #2
posted on Oct 31, 2009
Not Rated)
jackfrost555
Rank: Guru  Refrigerators  Expert
Rating: 91%, 109 votes
Solution #1 could well be one of the problems, however it is problem that can show up with certain types of produce, from time to time.
The crispers are at the lowest part of the machine, and thus the coldest area.
The complaints seem to come more often when the machine has light actively and colder temps in the kitchen and the cold air stratifies to the bottom.
The thermostat as it ages wears internally in a manner that causes a given setting to run colder albeit slight than when it was new.
Setting the control a half number or letter warmer, just may be enough.
I have had many old machines that although they ran fine had to be turned warmer to the point where they couldn't be set any warmer, yet still had a tendency to freeze. In that case the only solution was a new control.
P.S. your thermostat may have an internal calibration screw to compensate for altitude. This calibration screw can be used to adjust for a warmer setting if necessary.
Comments:
Oct 31, 2009
- I might add there is another school of thought about this problem, and believe me, it's a problem that's been beat around for a long time.
That theory is that the tstat should be set to a colder position, not warmer. The reasoning was that it would keep the fan running more often for longer periods of time preventing the coldest air from stratifying in the bottom. I guess it comes down to pick your poison.
Many years ago, frigidaire built a machine with a second fan motor in the fresh food compartment that ran all the time.
This machine never had this problem, but of course that was back when appliances were well build. Jack...
Was this helpful?
Yes
No
Solution #3
posted on Oct 27, 2009
Not Rated)
harry000
Rank: Guru
Rating: 89%, 14 votes
thermostat may be faulty
Was this helpful?
Yes
No
Popular Solutions for Maytag MFD2560HES Bottom
Questions and Unsolved Problems for Maytag MFD2560HES Bottom
Do you recommend Maytag MFD2560HES Bottom Freezer French Door Refrigerator?
Answer
Answer
My Maytag French Door, 25 cubic ft., Lower Drawer Freezer, Model MFD2560HES, refrigerator... (More)
Answer
light is on in refrigerator and freezer, but it is not cold. How do I check my fuses? The fan does... (More)
Answer
hinge for the crisper drawer broke. The long crisper drawer flips open and close with hinges on both... (More)
Answer
I have to replace the handles due to damage and I cannot figure out how to get the old ones off.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
