Question about Panasonic TX-26LXD1 26 in. LCD Television
No picture or sound
The standy by light on the tv flashes 7 times, there is no picture and no sound.
    Sniper:
  • 80 Answers
This generally indicates an issue with the backlight inverter loading the power supply. The inverter assembly is easily replaced in this panel and costs approx. $90-140 depending on your parts store. Please use caution when working with this component, it produces the very high voltages required to illuminate the screen.
Good luck to you.
J. Weibel
CustomElectronics.Org
Posted on Jan 01, 2008
Sony trinitron tv
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 24, 2013 | Televison & Video
My tv turns on but there is no picture or sound and it won't turn off unless I unplug it
i have the red light flashing 7 times then pause then flash again 7 times ?
Sep 30, 2013 | Panasonic TCP50S30 50 50 Plasma TV
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
My standy light keeps flashing and every so often it sounds like its gonna come on then it dont
There's no Picture coming out from the screen???even dark-fluctuating picture???
Does it blink?how many blinks interval?
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Sony kdf55sx955 has no sound or picture. Won't turn on. standy light flashing 6 times.
switch tv off for 10 min and then back on.
tv should come on.
if this doesn.t work.you will need to replace main board.
May 11, 2009 | Televison & Video
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Flashing standy light
This means Fan failure - A replacement will cure.
Jun 21, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Tv not coming on
There is a short on the B+ line caused by a pulse going through the supply, How is your insurance, it may be covered. windman
Feb 01, 2006 | Panasonic TX-26LXD1 26 in. LCD Television
Panasonic TX-26LXD1 26 in. LCD Television Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
