Question about Fuji FinePix Z1 Digital Camera
Battery i inserted my battery incorrectly and cannot take it out. i dont mind damaging the battery because i can buy a neew one. have you anyy suggestions that might help to remove th battery
    President:
  • 423 Answers
A tool known as "duck-billed" pliers works for the stuck in the wrong way battery syndrome. They are flat-nosed, pliers of the "needle-nose" variety.
Posted on Mar 04, 2008
GE Profile, model TFX28PPDA, leaks.
lifting arm turns off water no water no pressure no leak and yes filter inserted wrong -seal damaged or cross threaded will cause filter to leak
Sep 06, 2016 | GE Refrigerators
I have a ZTE MAJESTY W STRAIGHT TALK AND THE BATTERY SEEMS TO NOT WANT TO STAY CHARGED AND CUTS OFF AND THEY SAID THEY DONT HAVE AN EXTENDED BATTERY THEY WOULD SEND A REFURBISHED PHONE I DONT THINK THATS...
It's simple, a good innovator technician near you can assist. Just buy a better battery that can fit Ito the old battery slot and let the old casing be oped and the new batt casing removed. Resolver the terminals and insulate them before inserting old case now use it and forget the refurbished phone.
Jul 19, 2014 | Cell Phones
Does not power on
This may sound obvious, but the battery may be dead. In the event that the batt is just worn out, go get a replacement at any cellular store or somewhere like Best Buy or CompUSA. If the battery is not old enough to be shot, then check to make sure the charger is operating properly. Also check the USB cable and pay close attention to the charging port on the phone itself as it is not hard to damage the port by inserting the charging cable incorrectly. If the port is damaged, it will require service and is not field repairable. The battery and charging cable/adapter is easily replaced. Good luck.
Aug 25, 2013 | Samsung GALAXY S4
I have a 1997 chevy cavalier and some one replaced the side post battery i had with a top post battery since then all the idiot light stay on my lights dim off and on when i drive at night i had some one...
It is a ground issue, check to see if they have not installed a wrong wire to the power terminal instead of ground terminal, make sure the termainals are tight. Make sure the hood is not touching the terminals when you push hood down to lock.
Oct 05, 2011 | 1997 Chevrolet Cavalier
My mp3 player wont turn on but it works on the labtop how do i get it to turn on and does it need a charger or a neew battery if the battery level is low??????
The most likely problem is the rechargeable battery, if the battery is one to three years old chances are you need a replacement. But! there is the rare occasion the charger fails, when you decide to buy the battery have them check the charger first.
Mar 27, 2011 | Coby Audio Players & Recorders
How do i replace the batteries in this device?
To install the batteries:1. With the back of the radio facing you, remove the belt clip (seediagram below) for easy access, then remove the Battery Coverby pressing down on the top center and sliding it down from theradio.2. Insert 4 AA batteries observing the polarity as shown. Installingthe batteries incorrectly will prevent the unit from operating ormay damage the unit.3. Return the Battery Cover by sliding it up on the radio. Replace thebelt clip, making sure it locks into place.
To install the batteries: 1. With the back of the radio facing you, remove the belt clip (see diagram below) for easy access, then remove the Battery Cover by pressing down on the top center and sliding it down from the radio. 2. Insert 4 AA batteries observing the polarity as shown. Installing the batteries incorrectly will prevent the unit from operating or may damage the unit. 3. Return the Battery Cover by sliding it up on the radio. Replace the belt clip, making sure it locks into place.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Midland LXT310 2-Way Radio
My xbox fell over and scrached a game I clean it but it does not do enything
look at wikihow\ how to fix a damaged disc. you might have to buy a neew game
Nov 14, 2010 | Microsoft Xbox 360 Console
After inserting the batteries I do not get any lcd reading.
mcdevito75 here, Double check your battery insertion 1 of them or both incorrectly installed. If you"ve used to much pressure in installing the batteries you could have damaged the LCD display happens with Casio LCD"s. If the LCD display has turned color it may be shot. It may also be you need the press any function button to activate the LCD as when you installed new batteries it simply shut down.
Jun 25, 2010 | Watches
Ive had this probelm for about a month
Where did you get the battery? The battery may not be the one made for your mobile. Change the battery for original one. dont try to save money in case of your mobile. you will have to repent later.
Aug 28, 2009 | Sony Ericsson w580i Cellular Phone
Fuji FinePix Z1 Digital Camera Logo
49 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
