Question about Motorola Mobility A1200
Phonebook i can't add a contact to my phone book. i get a message that says it has failed to add the contact.
  • Anonymous Jan 08, 2008
    yes
Unable to save contact to my phonebook.
Posted on Jan 08, 2008
I want to block unwanted callers from calling me . i am unable to block these callers
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
Apr 11, 2011 | Samsung Star GT-S5233 Cell Phone
Tip
BLUEJACKING
<span>First up, you need to know what Bluetooth is. There are lots of types of modern devices that incorporate Bluetooth as one of their many features. PDAs, mobile phones and laptops are a few of these modern devices. Bluetooth means that Bluetooth enabled devices can send things like phonebook/address book contacts, pictures & notes to other Bluetooth enabled devices wirelessly over a range of about 10 metres. So, we've got past the boring part. Now, using a phone with Bluetooth, you can create a phonebook contact and write a message, eg. 'Hello, you've been bluejacked', in the 'Name' field. Then you can search for other phones with Bluetooth and send that phonebook contact to them. On their phone, a message will popup saying "'Hello, you've been bluejacked' has just been received by Bluetooth" or something along those lines. For most 'victims' they will have no idea as to how the message appeared on their phone.</span>
on Jan 01, 2011 | Cell Phones
My phone is a Samsung B2100, all my contacts in my phone book have mysteriously disappeared! When I try to add a new contact, it is unable to save it, however I can see that my contacts are still on the...
if the contacts are on the sim then remove the sim and put it in a new phone, put a new chip in the b2100 and search for the factory code in the phone's manual go to security search for factory setting and enter the factory code the phone will restart then put back the old sim.
Feb 26, 2011 | Samsung B2100 Cell Phone
SamsungGT-S5233-A:How do i block message from a particular mobile
1. press menu,
2. select settings
4. select call
5. select all calls
10. select call log
>>now you are all done.
>>no need to buy medicine for your head aches.. :-D
regards.
Mar 03, 2010 | Samsung Star GT-S5233 Cell Phone
Using the fax machine of Panasonic KX FT981, how can i add a contact (including its number) into the phonebook ?
Panasonic KX FT981
I am unable to rcv fax message because memory full messsage is diplaying.
How to delete memory
Pls help
Feb 24, 2010 | Office Equipment & Supplies
Samsung Gravity Phonebook problems.....says intializing phonebook
I have a gravity and when my was giving me similar problems I called there 24 support line and they can basically "refresh" the phone and once they did it to mine it worked fine.........hope it works for you
Sep 24, 2009 | Samsung Gravity SGH-T459 Cell Phone
Ka08 sms message settings
Hello, I had the same problem, but i figured out how to get the callers id/information. On the main page select Call Center>>Call History>> SIM1(or whichever you are using)>> and select either the Missed/Dialed/Received calls. Lets choose Dialed Calls for now. Select a phone number that you recognize>>select OK>>Options>>Save to Phonebook. In here you will create a new contact. Make sure you delete this old contact information from your phone book. (so you don't have doubles if already saved to your contact list). Now you can go to your main menu again and select the phone book option. Select the contact you have created and add a photo and ring tone you like. Now when you get a call you get their photo and rign tone. For sms you get only their name, but thats good enough for me.
Jun 26, 2009 | Apple iPhone 3G
Phone book pictures
make sure the pictures are saved to the memory card or the phone's memory
Dec 01, 2008 | LG KG800 Cellular Phone
How do you set up phone contact in phone book/ instruction book unable to be found how can I print a copy of the book/
Type the number you want to add, select ok or more or save then provide the information of the contacts you want to add......that's it you can add contacts now. Or you can also go to your phone Menu -> Phonebook -> Add contact then type the information for your contact....If this solution don't work, tell us what your phone unit so that we can specify the solutions to provide, thank you..........
Oct 06, 2008 | Motorola Cell Phones
Motorola Mobility A1200 Logo
93 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
