Question about Samsung SGH-D600 Cellular Phone
No power it wont come on unless its plugged into my computer!!!
Battery problem is what it sounds like
Posted on Jan 01, 2008
What does it mean when my hp desktop wont stay powered on unless my charger is plugged in
Desktop computers require power so you need to keep it plugged in. Laptops have batteries (making them portable) - if yours is a laptop and you have theses problems then either your battery is dead or you have a bad charger.
Sep 24, 2014 | HP Computers & Internet
Battery wont charge dell inspiron 1545
Buy a replacement cord\charger at a computer store or online, make sure the power specs match. If you are refering to the AC power plug JACK in your computer, similar to this:http://www.parts-people.com/index.php?action=item&id=9377&gclid=ciw47k7sulmcfqufnqodreeaew. I would take it to a Qualified Computer tech, or send it to the manufactor, Dell in you case. Unless you have the tools and expertise. It can be done but are you comfortable doing it?
Nov 04, 2012 | Dell Inspiron 1545 Notebook
When you plug the power cord in the lap top does not even power up there is nothing
Your power supply is either faulty or your computers power supply area is faulty, if you have a light on the power supply usually green, you can tell that way if your power supply is working, the other way to tell would be a multi meter checking dc voltage from the power supply's end, if you get around 13-14.5 volts somewhere in that area, then it is supplying voltage and is okay, which would mean it would be your power supply in the computer on the motherboard is faulty, which needs serviced by the company if under warranty or computer tech, if your power supply is all the way in and plugged in the laptop, it's usually one of those two issues, it can still work on battery and sometimes it wont if it is the computer, i would first suspect the power supply itself first, and check it while plugged in , even plug it into another outlet just to rule that out. if the power supply is bad and you replace it, the computer should work fine, unless there is internal damage in the computer. Hope this helps.
Dec 01, 2010 | Computers & Internet
Mi navman my55 wont turn on unless it is connected to the car power supply it is reading the batt is full and wont turn on even if connected to computer or power plug
my navman 55 has developed a problem it will not arrow down on any screen and the touch screen has been hard to operate from new
Aug 04, 2010 | GPS
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
Computer wont turn on with 750 watt power supply
Make sure the PSU itself isn't dead, if not, then make sure all the plugs that were required before in the 300 watt, have plugs for the 700 as well. There is also a small chance the motherboard cant handle that much wattage, if its an older model.
Dec 29, 2009 | Dell Inspiron 531s Desktop Computer
Charging issue
It’s either the plug on the AC adaptor (might have a broken wire) or the laptop’s input jack that the adaptor plugs into. The input power jack is soldered onto the motherboard. Could also be a problem with the charging circuit on the motherboard (would need to replace motherboard to fix).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 15, 2009 | Dell Inspiron 9100 Notebook
Well my Sansa e280 wont come on. But when i plug it up to the....
Change the USB mode from MTP to MSC and see if that helps.
Also, make sure the hold/lock is not engaged.
Jan 06, 2009 | SanDisk Sansa E280 MP3 Player
Toshiba Laptop wont work unless plugged in, i recently bought a new battery think that the battery was the problem and still it doesnt work unless its plugged in. please help me!
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
May 13, 2008 | Toshiba Satellite P105-S9722 Notebook
Samsung SGH-D600 Cellular Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
