Question about Dell A960 All-In-One InkJet Printer
A 960 all in one ink jet.
When my printer is sent a job it will print. However, thejob display on the computer says 99% complete. I have to then turn my printer off and back on again in order to print another job. Also, my new ink cartridge will not align.
Thank you for you help.
  • MCaulfield Nov 05, 2008
    I followed all the steps including the firmware upgrade. No print job gets past the 99%.
    I cleaned the copper contacts even though the print cartridges were recognized. Then I: 1) uninstalled the software and drivers, 2) reinstalled software and drivers from the original install disk, 3) downloaded the new drivers and firmware upgrade from the website, 4) installed the firmware upgrade, 5) updated the drivers. The problem persists.
  • ladyathegate Nov 30, 2008
    When printing on my A960, the pop-up shows the job to be 99% complete. In order to print another job, I have to turn the printer off and then on again.
  • 2,351 Answers
Remove the new ink again. Take a couple cotton swabs, lightly dampen with water. Clean the copper contacts inside the ink holder. Also clean the copper on the ink cartridge. Do not clean the bottom (where the ink comes out). You can wipe this with a lint free clean cloth. Did you remember to remove the protective tape on the new cartridge? Sometimes the tape stays & you have to look close to be sure. There is a firmware update for the A960. Also a good idea to install. Download here:
You can clear a print job by, click the start button, open printer & faxs, right click on the default printer which should be the A960. Click open, click printer, click Cancel all documents.
Lets see what happends after all the above.
Posted on Jan 30, 2008
I already refill hp 960 catridge but printer show ink catridge depleted.. so what i do
the micro chip reads the amount of pages already printed but cannot be reset. Only way to remedy is get a refilling company to supply another chip.
Aug 06, 2014 | HP Office Equipment & Supplies
Error 49.33.03
First turn off the printer and then delete the job held at the computer in the print queue. Then turn the printer back on. The error should go away. Try printing the document again to see if the error returns. Normally a corrupt print job causes this issue. If the error appears with no jobs being sent to the printer then the formatter board is most likely bad.
Mar 10, 2014 | HP Color Laserjet Enterprise Cp5525n...
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
I have a primera signature 4 ink jet CD printer. It will not print and the left green light on top is flashing very fast.
The printer lighting symbol indicators are messages of replaceable resources either paper or ink. usually the printer is expected to perform until a fault displays a logo either green for functionality, pink of resources shortage, and red for power resources insufficiency. Checking on the printer compartments to ascertian the conditions or replaceabel resources paper, ink, or jams due to paper over loads. Computer messages with printers would display the fault. For example, a printer message on the computer either as print job request unsuccessful or requirng software would be observable from the computer screen.
Jan 14, 2011 | Primera Technology Primera SignaturePro CD...
Error 79.00FE
In order to fix the 79.00FE printer error, first you have to print a configuration page. Then remove the jet direct and power on while holding the go button down on the printer. After display reads offline, the reset process is complete. After the cold reset, remove the jet direct card and see if the 79.00FE error goes away. If the 79.00FE error appears before a job is sent then it may be the DIMMS, try removing them to see if the error persists.
Dec 08, 2010 | HP LaserJet 5100dtn Printer
I have a HP 4385 --how do you cancel a print job---it was sent a print job multiple times (over 10) from a Mac and i do not know how to cancel these jobs as they were sent in error and are huge ink...
The printer should have a stop/cancel buttom on the panel, just press that and it sould cancel the print job.
Also, you can delete the job queue from the computer. You should have a printer in the Dock, click on that and select jobs and click on the delete button. If you don't have the printer on the Dock, click on Apple, System Preferences and select Printers. Select your printer and click on Open Queue and delete the jobs from there.
Dec 02, 2010 | Office Equipment & Supplies
Printhead (R), Check Printhead - Canon IPF5000
that confirms Right Print head is may be Out of Ink or near to low ink level.
check whether there is any option to Disable Alerts in printing preferences..print settings >> printer settings
Feb 18, 2009 | Canon imagePROGRAF iPF5000 InkJet Printer
Cannon i 960 printer
Try first replacing the cartridge , possibly with an original one.
With new printer cartridge on do head clean a couple of times, to clean the print head.
If it still prints wrong color then the print head is faulty, one of the colors jets is clogged.
You can remove the printhead and leave it in cleaning solution or isopropyl alcohol overnight, probably you will need to replace the printhead.
Sep 10, 2008 | Office Equipment & Supplies
Document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Dec 18, 2007 | Lexmark X5150 All-In-One InkJet Printer
Dell A960 All-In-One InkJet Printer Logo
46 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
