Check to see if you are running out of ink... if u still have plenty ink in store then check if it is install properlly, then check for the printer setup
The ink failure error is caused by air in the ink feed tubes in your
printer. This happens when the ink in your cartridge runs out and the
printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair
solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: printer is showing a system
I had the same problem & found the solution of HP's website. It solved the problem.
HP Website & solution:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489814&dlc=en&product=1153494
Solution one: Reset the product
Use the instructions below to resolve the issue by restarting the product.
Solution two: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
SOURCE: ink system failure was working fine the I stopped
Found on HP Web The link is below. If you find this helpful, pls rate me.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00723815&dlc=en&product=1153494
This document applies to the HP Photosmart C6150, C6170, C6175, C6180, C6183, C6185, C6186, and C6188 All-in One.
Issue
An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The all-in-one cannot copy, receive faxes, or print.
Solution
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the all-in-one.
Good Luck.
