Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Just moved tv and now will not power on. i do hear click noise in speaker ,
Move tv and now it wont power on. I do hear a click noise about 3 times when switch is pushed. switch will not light. help please
    President:
  • 1,314 Answers
If that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rcajust moved tv and now will not power on. i do hear - 2.gif cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Posted on Jan 02, 2008
Multiple issue,power light flashes
Sounds like first loose connection on circuit board. I would first look around the relay this is what clicks. Then also the low voltage transformers. These problems are always concerns when set is moved or bumped hard. Try this first. Or it could be a heated issue.
Nov 26, 2007 | Philips 50P8341 50" Rear Projection...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
No Transmitting, no RX sound, but can hear speaker click on...
Hi there!!
The symptom sounds like a bad Microphone connection or a bad microphone!! The Cobra has a built in circuit that wont allow you to hear anyone until the microphone is plugged in and the no transmit part will also do the same. Try another microphone that is wired right for that radio before you do anything else!! let me know!!
Dennis
Mar 18, 2009 | Cobra 29 NW CB Radio
No sound tv
it can be many reasons
1 some tvs have on the back a internal/external speakers many times the customer unadvertidly move the sw to the expternal position
2 the speakers are deactivated from the man many
3 check if the tv has a his noise coming out from the speakers at full volume if so then the amplifier are good & the same for the power supply if no hissing noise then check dc votege is geting the amplifier if so then the amplifiere is most likly the fail if not then the power supply is at fault
3 check for the output capacitor that most of the amplifiere have in the output is conected directly to the speaker
4 if no capacitor is found then it must be +B & -B in order for the amplifier to work the lack of one of them mus make the amplifier unoperable then define why is not ther & fix the cause
Feb 03, 2009 | Televison & Video
Clicking noise in the back of tv and wont come on no standby ligh
The TV is in protection mode because of a fault with moving it and then coming on briefly I would suspect that the fault is a dry joint ( a solder joint which has fractured) finding it can be time consuming but it is most likely to be around the caps in the line output stage which need resoldering.
SUPER8
Dec 01, 2008 | LG 30FZ1DC 30" TV
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Dec 14, 2007 | Kenwood VR-507 Receiver
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Klipsh Promedia 2.1
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Sep 10, 2006 | HP ProMedia Computer Speakers
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
