Routers
Problem for Routers
Generic problem for all Routers
Reset my IP Address
By mr_ojeda_ben on Oct 27, 2009
Reset my IP Address
Clarification Request
Posted by mjebend on Oct 27, 2009
please explain a little if what you want to do is change the external IP adress to the router simply unplug the cable modems power for 15 min and the router do a rest on the router once you pug the modem back in and turn the power on the modem will rest itself and isue a new IP to the modem and router. example the modem will remember the mac address of the router so unless renewed the modem will hand out the same ip each time to the same router you will need to clear the modem first and un poerw all devices if you do not turn the power off the router then the modem will reisue the same IP to that modem most the time.
Posted by rawright486 on Oct 27, 2009
Most routers come with a default address, usually 10.0.0.1 or 192.168.0.1, which are addresses on network numbers reserved for private networks. These are changed routinely to match the internal numbering scheme of your network. The procedure, however, depends on the manufacturer and model of your router. There is no generic procedure for doing this. Also, there are at least two addresses on a router - the local IP address (LAN) and the remote IP address (WAN). Both need to be set correctly for the router to operate. For Internet use, the WAN interface is uaually set to use DHCP, which automatically receives its address from your service provider , but you must set the LAN interface yourself. Again, the process is specific to each device. Check the manual - you may have to download it from the manufacturer's website - or repost with more information about your router.
Posted by milleraba on Oct 27, 2009
and what pray tell is your question????? Good questions get good answers aat FixYa.com You got a question... we will try to answer it. Thanks for visiting. a
Solution #1
posted on Nov 12, 2009
Not Rated)
reshavarora
Rank: Wiz
Rating: 79%, 6 votes
You can can reset your IP address by :
1. Opening the Windows Command Prompt located in Start -> Accessories or
Start -> Run -> Type in either "cmd" or "cmd.exe" (without the quotes)
2. Type in "ipconfig /release" (without the quotes)
3. After releasing the IP, typie in "ipconfig /renew" (without the quotes)
If the instructions above doesn't work, you can set a manual IP address by :
1. Going to Network and Dial Up Connections in the Start -> Control Pannel
2. Going to your local area connection
3. Click "Properties"
4. Click "Internet Protocol (TCP/IP)"
5. Then again click "Properties"
6. Selecting the "Use the Following IP Address"
7. Entering an IP address available on your network
Was this helpful?
Yes
No
Solution #2
posted on Oct 27, 2009
Not Rated)
govinda123
Rank: Guru  Computer Networking  Expert
Rating: 90%, 130 votes
You want ot reset the router or the IP address of the computer.
If you want to reset the router then you can press the reset button on the router.
But if you reset the router , you will loose all the settings of the router.
Click Here to know more about routers and network
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
we have lost connection from our lap top and the wireless light on the router is out. i hope you can... (More)
Answer
Belkin router wireless is good with green lights on, but modem light is flashing. What seems to be... (More)
Answer
I've had 4 LinkSys routers over the past 4 years. 2 were 4 port wired, the other two were 4 port... (More)
Answer
unable to comunicate with 4800 printer all other two laptops ok it was working very good for long... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
