Home | LG | LFX25960ST Stainless Steel French Door Ref... | Error code er ff.how do ...
LG LFX25960ST Stainless Steel French Door Refrigerator
Problem for LG LFX25960ST Stainless Steel French Door Refrigerator
Error code er ff.how do i fix this?
By jenkinsdarre on Oct 27, 2009
error code er ff.how do i fix this? freezer is still freezing but fridge is warm.
Best Solution
posted on Oct 27, 2009
Very Helpful)
jan mczeal
Rank: Guru  LG Expert
Rating: 87%, 235 votes
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" thanks, that made it a lot easier " - jenkinsdarre
Solution #2
posted on Oct 31, 2009
Not Rated)
jen3713
Rank: Apprentice
Rating: 0%, 0 votes
We got the same problem. This model is a total POS. We had to empty the fridge and let it thaw. LG told us the freezer fan froze up. Sure enough after 24 hours, there was a puddle of water under the fridge. Now that works, but the ice maker broke. Not what you'd expect from a $2500 fridge. There are TONS of complaints about this out there.
Was this helpful?
Yes
No
Popular Solutions for LG LFX25960ST Stainless Steel
Questions and Unsolved Problems for LG LFX25960ST Stainless Steel
Do you recommend LG LFX25960ST Stainless Steel French Door Refrigerator?
Answer
Answer
no ice being made. water is connected and being dispensed. sensor arm is in correct position. new... (More)
Answer
My three door fridge will not make ice last week it stopped making ice we turned it off for a few... (More)
Answer
The refrigerator just stopped working it is 18 months old
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG LFX25960ST Stainless Steel...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
