Husqvarna Chain Saw 20" Bar
Problem for Husqvarna Chain Saw 20" Bar
Husqvarna 55, 20
By drc114 on Oct 27, 2009
Husqvarna 55, 20". Clutch worn. Looking for step-by-step on replacing worn clutch assy.
Best Solution
posted on Oct 27, 2009
Helpful)
mrfixit-jerr
Rank: Guru  Tools - Building & Power  Expert
Rating: 94%, 8029 votes
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Thanks. I'll try it. " - drc114
Solution #2
Very Helpful)
dontbother10
Rating: 98%, 872 votes
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
Lou
Line 2 may save a little hair and a couple of $. The hair is important in my case. LOL
Was this helpful?
Yes
No
Popular Solutions for Husqvarna Chain Saw 20" Bar
Questions and Unsolved Problems for Husqvarna Chain Saw 20" Bar
Do you recommend Husqvarna Chain Saw 20" Bar?
Answer
Answer
runs until I start cutting something, then turns off.
Answer
I had water in my hydraulic fluid in my Komatsu D39P dozer. I opened the drain plug, drained the... (More)
Answer
stihl ht75 wont start. Its almost new!
Answer
unable to pull starter chord seems to be locked
Answer
I have a craftsman electric stapler model #68496 and I need to know how to load the staples.
Describe your Chain Saws problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Chain Saw Experts
Top Garden & Power Tool Repairmen
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
