Question about GE Profile JGS968 Gas Kitchen Range
Can i swap the broiler glow bar for the oven glow bar
Its new years i need to bake a ham, how can i swap glow bars to get my ham going ?
  • kuszaj Jan 01, 2008
    i just got done cooking the ham on my gas grill, how do i get the oven glow bar out to fix the oven?
    Sergeant:
    Champion:
  • 310 Answers
I disagree with fix it right. Im from the old school days and was poor. if you pull real hard the element will pull out of the socket and it rest on its supports. plug it into the other sockets remember to cut power all ways first. i have a oven so its a visual thing with me. Im a ham lover so enjoy.
Posted on Jan 01, 2008
    Sergeant:
    Champion:
  • 262 Answers
Changing glow bars are not recommend the bake and the broil have different ohm values and probably wont work
  • Bill Dozier Jan 02, 2008
    JESSEE WE ARE TALKING ABOUT A GAS OVEN NOT ELECTRIC I TOO LOVE HAM BUT GLOW BARS HAVE DIFFERENT VALUES TO PULL IN THE VALVE BUT BACK TO THE SUBJECT YOU HAVE TO PULL THE RACKS FROM THE OVEN CAVITY IN THE REAR MAY BE TWO SCREWS REMOVE THESE AND PULL UP AND BACK ON THE BOTTOM COVER THIS WILL LET YOU SEE THE GLOW BAR IT HAS CERAMIC
    AND A;MOST LIKE A WIRE LOOKING THING ON IT ON THE BRACKET IT HAS TWO SCREWS REMOVE THESE AND AND GLOW BAR IS IN YOUR HAND FOLLOW WIRES BACK AND UNCONECT THEM REPLACE IN THE REVERSE WAY REPLACE VALVE AT THE SAME TIME ITS A VALUE THING ON THE BAR AND THE VALVE TRUST ME 25 YRS DOING THIS THERE ARE WAYS TO DO THINGS AND THEN THERE IS THE RIGHT WAY.ANY MORE QUESTIONS EMAIL ME BACK ANYTIME
Bottom oven does not start
I HAD THIS SAME PROBLEM THIS WEEK. MY REPAIRMAN TOLD ME THE GLOW BAR IGNITOR ARE BAD TO GO BAD. EVEN IF IT STILL GLOWS IT PROBABLY ISN'T PUTTING OUT ENOUGH GLOW TO OPEN UP THE SAFETY GAS VALVE. I THOUGHT MY PILOT LIGHT MIGHT BE OUT, BUT THEY DON'T EVEN HAVE ONE FOR THE OVEN/BROILER IN THE BOTTOM OF STOVE, BUT IT DID HAVE ONE FOR THE TOP BURNERS.
YOU CAN WATCH SOME YOU TUBE VIDEOS OF HOW TO FIX THE GLOW BAR IGNITOR FOR THE OVEN AND LEARN MORE--HOPE THIS HELPS..
Jan 23, 2015 | Ovens
The broiler works but the bake option doesn't work, the oven doesn't get hot, any suggestions?
Check the bake ignitor (glow bar attached to the burner). If it does not glow at all, but the voltage is supplied to it - replace. If it does glow, but draws current less than 3A - replace.
Oct 14, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Gas Oven - no flame at Bake Baffle - Glow Bar glows fine
If the glow bar is working (glowing) it is the gas valve. BUT, the glow bar can also actually glow and still not be working 100% and letting enough current through to the valve. You could swap an identical valve out to check it, if you don't have a meter. It's more than likely the valve though.
Jul 23, 2009 | Kitchen Ranges
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Kenmore gas range model# 362.72321 Oven will not ignite (sometimes)
Range Oven Temperature Sensor Part Number WB20K0004 Sears PartsDirect
This will be why the oven acts up. The broiler doesn't rely as much on this as the bake part does. Replace this and it should fix your problem.
Jun 14, 2017 | Ovens
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
BAKE SECTION OF OVEN FAILS TO IGNITE BROILER LIGHTS
Hi thanks for your question. its more than likely the glow bar you can remove it to check for a break in the heater, they are fragile. but it is a common problem i would change it. thanks the appliance doc. please rate, my answer, thanks
Oct 14, 2008 | GE Profile JGSP48 Gas Kitchen Range
Broiler glow bar stays on
the glow bar stays on in gas ranges the whole time the cycle is running if it didn't the safety valve couldn't open its normal
Jan 20, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Oven "bake" doesn't work...
sounds like the bake glow bar needs to be replaced it is under the bottom cover inside the oven good luck
Aug 29, 2007 | KitchenAid KGST300 Gas Kitchen Range
GE Profile JGS968 Gas Kitchen Range Logo
180 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
