New Acer Aspire E700 does not load-up
Brand new Acer Aspire e700. All cables connected. Push poer button and fan starts buiy nothing else. The pre-loaded software does not install & the monitor is not receiving any signal
    Scholar:
  • 131 Answers
Does your BIOS POST runs then you might be having a Disk Booting Problem, If you dont see your BIOS POST Screen, then check if you can hear any beep sounds, If you hear beep sounds check the ram whether it is properly inserted in the ram slot or the ram might be faulty.(You may have to change the Ram). If you dont hear any beep, check whether the buzzer(Speaker in the CPU) is working, If buzzers were working fine before, then you might be having problems with your mother board or processor. If you know how to work on such problem try reinstalling the processor, ram etc in the cpu . Otherwise call a service engineer to have the job done.
Posted on Jan 01, 2008
My pc wont load it will just on just a sec then turn off
there might a problem with motherboard
remove the 4 pin jack of power supply and turn on the pc if it starts properly means all the fans turns on there is problem with your motherboard
May 21, 2014 | Acer Aspire E700 PC Desktop
Computer won't start at all - continuous long beeps
One long beep probably indicates that the memory chip(s) are not inserted properly.
Jan 19, 2014 | Acer Aspire E700 PC Desktop
Computer won't start continuous long beeps
Probably means the memory chip(s) are not inserted properly
My Acer Aspire E700 will not start up. When I press the power button, you can hear it begin to start but then nothing. Almost like a car trying to turn over is the only way to discribe it.
you could have a bad video chip. Failure to POST could mean anything, but most times it's a video chip. Still, you can try re-seating your ram chips, re-seating your CPU, and re-seating the add-on cards that you may have.
Sep 22, 2012 | Acer Aspire E700 PC Desktop
I changed the power supply on my acer aspire e700 and it beeps continuosly non stop with no picture on screen, the last power supply blew. it had a graphics card when i bought it but it stopped working so...
You may have more problems than just he power supply from when the old power supply went out. The mainboard could be bad.
Make sure it's unplugged from power from the wall, then check that the memory is seated correctly. Check for anything else that may be out of place or not fully connected.
There are also different beep codes for different errors. They've mostly been standardized, but may vary by mainboard as well. Here's a link to common POST beep codes and their meanings:
Computer POST and beep codes
May 19, 2017 | Acer Aspire E700 PC Desktop
How can I install an addional (second )DVD drive in my Acer Aspire E560 desktop? A link directing me to step by step instructions (with photos) would be perfect. Thanks
Starting on page 55 of http://www.manualowl.com/m/Acer%20Computers/Aspire-E700/Manual/114116 you can see the diassembly instructions with pictures. Use as much of the guide as you need, but when you take the case off you'll be able to see the HDD and the first optical drive connected to the front of the computer. If your system is identical to the one pictured, you'll need to remove a little cover directly under the primary disk drive. Then slide your new drive in from the front until it slots into place (there may be screws to hold it into place). According to the manual I linked, you should have a few extra SATA ports on your motherboard (the primary disk drive and/or harddrive should have one coming out the back. follow it to where it leads and you'll see other similar ports to plug your new wire into). If it's not SATA, it's IDE, which is a wide, flat cable (approx two inches wide). The principle is the same regardless...Find the port to plug it in, then plug it into any available SATA/IDE port. Next, plug in the power cord (should be a 4 wire plug if IDE, or another flat cable similar to the SATA cable, but wider). Once that's all hooked up, reverse the disassembly instructions you followed, put the cover back on, and boot it up. Most drives are plug and play, so you shouldn't need to worry about installing any drivers or anything. If you do, just install them like you normally would, restart, and you should be good.
Good luck, and it's much easier than you might think at first :)
Jun 14, 2011 | Acer Aspire E700 PC Desktop
Acer Aspire E700 running Vista. After a complete shutdown either from power interruption or normal windows shutdown, will not power up, no POST, no lights on front panel, nothing, unless usb devices are...
I have never heard of such a symptom, but if there's no power it can only be one of two things. Either there is something very strange going on in the power supply, or you have a motherboard with some problem. My feeling is that it's the motherboard, though.
The power switch only sends a signal to the motherboard to turn on the power supply. I have to believe that some problem with the USB controller or the USB power on the board is interfering with the board's operation.
It would be fairly easy to substitute a known good power supply for testing. If you still have the trouble, I'd say it's time for a new motherboard.
Mar 07, 2010 | Acer Aspire E700 PC Desktop
I got a friends acer aspire E700 and kids got to
just check with ram if there is 2 diffrent ram just remove one and try for installation.
Jan 25, 2010 | Acer Aspire E700 PC Desktop
Want to download pictures from phone to computer or other device or memory card.. need help????
you will need the samsung e700 data cable & software suite, i would suggest you order it from samsung.com. (you will be able to download pix,audio,etc to pc and vice versa)
May 17, 2009 | Samsung E700 Cell Phone
Picture does not fill Screen
It is displays fine up unto the point where Vista loads, then it must only happen when Vista loads the display driver. I would go with your initial assumption and reinstall the display driver.
Jan 15, 2009 | Acer Aspire E700 PC Desktop
Computers & Internet Logo
199 people viewed this question
David Payne
David Payne
